Page 2 of 4 1 2 3 4
Re: Idle Air Control [Re: homerdog] #955147 07/28/09 08:31 PM
bombardj1 Offline
a lot of times when someone changes the plugs, they get codes for miss fires, this is most likely the wiring harness because with age they don't hold together. try the different part hope it works
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Idle Air Control [Re: bombardj1] #955148 07/28/09 11:43 PM
Hydra747 Offline
I got one..........PM Me
Re: Idle Air Control [Re: Hydra747] #955149 07/29/09 01:33 AM
homerdog Offline OP
I went back to the junkyard and tried out the one they had. same results. so I'm back to the drawing board. I'll recheck all the wires tomorrow and replace the one coil that I know is going bad.
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955150 08/02/09 05:19 PM
homerdog Offline OP
Fixed!!!! Whoever the big dummy is that worked on the thing last (I won't name names, hehe) switched the two plugs around. Well anyway, I got a new set of plugs and wires installed, a new coil, cleaned the MAF thingie and the throttle plates. So now I shouldn't have to mess with anything, at least for a little while.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955151 08/02/09 09:46 PM
Hydra747 Offline
Fixed!!!! switched the two plugs
What plugs?
The o2 sensor or the spark plug wire?
Thanks
Re: Idle Air Control [Re: Hydra747] #955152 08/02/09 11:07 PM
homerdog Offline OP
The black 4? wire plugs that plug into the air intake between the MAF and the throttle body, one is the idle air control and the other one plugs in right next to the throttle body, they are both the same and I didn't think they were so I didn't bother checking them until this last time I tried to fix it.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955153 08/02/09 11:52 PM
Everet Offline
GOOF!!! <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
At least you found that goofballs error... <img src="/forums/images/graemlins/pfft.gif" alt="" />
Keep us posted!!!
Re: Idle Air Control [Re: Everet] #955154 08/03/09 12:37 AM
Hydra747 Offline
Now I see,
And unless it is super brand new and was like sitting in moth balls.............
The connector should be slightly bent towards the correct connection.......LOL!
Glad u found it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Idle Air Control [Re: Hydra747] #955155 08/03/09 02:17 AM
homerdog Offline OP
The wife is pretty happy I found it too. I was walking around in a really pissy mood for a few days trying to figure out what the heck could go bad so fast. I walked in the door after I fixed it and told her some dumbass had the connectors mixed up and all she did was shake her head and laugh.
The other plug must be the throttle position sensor.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955156 08/03/09 02:40 AM
bombardj1 Offline
bad left hand not watching what the right hand was doing, it needs to be slapped with a ruler, oboy do I remember having my hand slapped with a rule in the 2nd grade by my teacher, and yes they did way back when, Everet might have had 1 or 2 back then, how about it Everet?
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6435 MB (Peak: 0.7482 MB) Data Comp: Off Server Time: 2026-06-10 06:09:38 UTC
