Page 4 of 4 1 2 3 4
Re: SAS Discussion/Idea Thread: [Re: TOASTY] #955288 07/25/09 09:52 PM
0778drz110 Offline OP
Stock Wagoneer springs.
Thats a nice stance! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Did it rub like that? Any contact problems with the diff and oilpan/frame?
If you wanted an SAS to be as "stock" as possible you'd want a Early bronco D44 and it's 2 link setup. This is the easiest way to do the swap, it's a little more expensive than the wagoneer swap but once you did it it would be cheap to maintain. I was doing this setup but then changed my mind in favor of using montero 2 link with waggy D44 (having an axle pile is not as cool as it sounds).
LR, yeah LT's is a budget SAS I think he's less than $200 into it ($150 being the D44) and all steel but the rear perches has been scrap metal. I'm gonna run Gen 2 two link up front on mine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
and Angelo if someone were to produce a SAS kit it could fit '83-'00 Monteros easily.
I recently bought a Bronco II with an EB D44 up front, I agree. Not to mention extended radius arms and some other stuff you will get good flex <img src="/forums/images/graemlins/cheers.gif" alt="" />
And for those that complain about your montero being slow, It still has the stock EB gearing, 3.08s. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Its not that bad... <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: SAS Discussion/Idea Thread: [Re: 0778drz110] #955289 07/26/09 05:10 AM
LandRaider Offline
Rubbed the back side of the fenderwell / floorpan area JUST a tad. This is because I run a shackle reverse setup, so when the springs compress as the tire moves up, it also moves slightly rear twards the footwell area.
I never had concerns with it running the frame, or motor.... but of course I don't run a mitsu engine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5968 MB (Peak: 0.6628 MB) Data Comp: Off Server Time: 2026-06-24 20:09:58 UTC
