Re: here is what I done did today
[Re: 93montero_sr]
#955554
07/26/09 08:02 PM
im sure someone will chime in and say im a moron and all that because some people on here are just like that. john <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Not here we all look out for each other <img src="/forums/images/graemlins/kewl.gif" alt="" /> No, if you mix them they will gel and ruin the compressor and other components. Also, the oil that is used in the r12 system is not compatable with r134a and will not flow thru the system properly causing the clutch on the compressor to not disengage. If you decide to retro fit your vehicle your need to replace compressor, orfice tube, condensor, the fittings and the evaporator, so pretty much all the components and the system need to be evacuated and vacuumed so there will not be any moisture or air in the system. Well I live in florida and just recently My AC-Which was still R12 started getting warm after a bit. I ended up changing out the Fan 1st. then I added 134 and since it's cold as can be in 90deg heat. Just Drove to Itchtucknee springs (210miles one way) and back the other day with 7people in car (Jump seats mounted) me and front passeneger FROZE trying to keep everybody coool in back <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: generation_one]
#955555
07/27/09 12:46 AM
Mixing 134 and R12 is against federal law. Not thatÆs is going to be a huge deterrent, do whatever you want. My take is that that once you have the two gasses in one system its hard for a shop or the next owner to properly dispose of the refrigerant, unless you "Vent" it.
The good thing is the ozone layer is getting better and by 2050 it should be back to what it was in the late 80's.
If you convert to R134 and donÆt change out the mineral oil the compressor life will be pretty short. Mineral oil is not miserable in R134. It wonÆt flow with the refrigerant so the compressor wont get a constant supply of oil.
There were a lot of studies done on conversions and the failure rates. Even done right the R134 conversions had some problems but nothing like the failure rate of one thatÆs done wrong.
The down side is R134 is a serious greenhouse gas.
Just so you know....If ANYONE calls me a tree huggerà. IÆm going to call them a moron. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Seriously, ItÆs easy to take shortcuts and say what one person does wont matter. Its just me, I donÆt believe in the ozone hole and r12Æs effect on it and whatever. The problem is lots of people have the same attitude and repeat the same action to the point where it makes a difference.
I know... What socalist, liberal, Obama voting a tree hugger. <img src="/forums/images/graemlins/rodent.gif" alt="" />
Kevin
[Re: Kevin C]
#955556
07/27/09 01:15 AM
Depending on the shop, it shouldn't be hard to dispose of mixed gases. A small general mechanic shop doesn't have the equipment, though.
We have a gas sniffer that tells us what a system contains: R-12, R-134a and air - and what percentage of each. If it's 97-100% R-12 or R-134a, we vacuum it into a tank designated for whatever it is, but if it's mixed and less than 97% pure, we vacuum it into a tank for mixed gases.
The main reason we run 3 separate tanks is because we can sell R-12 or R-134a for a decent price as long as it's at least 97% pure, but we have to pay to get rid of a mixed tank. We do a very good job of identification and recovery, so most of our tanks are 100% pure.
The equipment to do that costs about $2000 - the reason why most small shops don't fool with it.
Frank
[Re: FrankR]
#955557
07/27/09 09:14 AM
so frankR is a refer man? interesting.
Do you think my god-given birthday sniffer will work? I dont need the percentages...just want to know what is in there now so I can top it off. Optimistically thinking that it was done right to begin with - no air or mixed gasses.
Does 134 react to the old copper/propane leak detector? Maybe that is better idea.
I dont use AC anyway...but it's just the principle of the thing.
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: FrankR]
#955558
07/27/09 04:18 PM
Frank, can I swing by for an R12 refill? <img src="/forums/images/graemlins/smile.gif" alt="" />
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: joestruck]
#955559
07/29/09 10:23 PM
I did the R134 conversion kit with sealer when my R12 system wasn't working, and it has been working great for months. One of the best things I have done for my $300 traesure.
[Re: 87Montero]
#955560
07/30/09 12:41 AM
so frankR is a refer man? interesting. No, I'm not - I'm just a junkyard dog. <img src="/forums/images/graemlins/wink.gif" alt="" /> Frank, can I swing by for an R12 refill? No, I'd get in trouble for that. <img src="/forums/images/graemlins/wink.gif" alt="" /> Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
