Page 2 of 3 1 2 3
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: rolling_down_the_hill] #955601 07/26/09 08:32 PM
LandRaider Offline
having a tire stick out isnt going to prevent you from body damage. the more you wheel and the better you get helps prevent it, but if you wheel you get body damage.
It's certainly going to help. It doesnt matter how much skill you have. The wider tires keep your body off of the washouts. Where I am at, we frequently wheel in places where the sides of your vehicle WILL come in contact with the ground/trees/rocks, and if you've got skinnies tucked up inside the fenderwells, there is nothing to keep your fender from getting trashed.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: LandRaider] #955602 07/26/09 09:49 PM
Angelo Offline
wider tires will help keep the body away from walls, not just skill alone
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: Angelo] #955603 07/26/09 10:50 PM
Wheeling causes body damage. Fat tires do help keep it to a minimum + on the heavier rigs (Gen2's and 3's) you get better contact pressure to the ground with the wider footprint. Skinnies do [censored] rock on the shortys though, so buy a deep wheel or a thick spacer.
Guess what saved that side of the body, minimal damage <img src="/forums/images/graemlins/kewl.gif" alt="" /> You go PA_JERO!.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: LandRaider] #955604 07/26/09 11:19 PM
DRaider90 Offline OP
1.)Didn't mention running 11.5s on 15x7 or 12.5s on 15x8s. Those are actually the proper widths for those rims sizes. I am talking running a 9.5" on a 7", and a 10" on a 8". Guys that run the 34x9.5s like that I have on 7" rims pop a lot more beads than on the 6" rims, and you are more likely to pop a bead with a 10.5" on an 8" rim than a 12.5".
@ SandRaider glad you didn't pop a bead at 11psi, but in the lower ranges 6-9psi I am sure you would be more likely to pop one with the 10.5s than the 12.5s you have now.
@ Icy an 11.5" wide tire is ideal for a 15x7" rim. I was talking 9.5" on a 15x7". And good luck with the LTBs. The 34x10.5s were my second choice, but they have less tread and run smaller than the 9.5s do so that influenced my decision.
2.)Wider tires help keep the truck up off of walls etc. There are many cases where you are in rutted areas with high mud walls where skill and winching isn't apart of it.
The ruts shown above are stepped to where your drivers side wheel goes up in the air 3-4 feet pushing your passengers side into the wall. If you have wider tires they hit the wall before the body does, and keep you from experiencing body damage. Anyone that doesn't believe this I can show you the pictures of my damage, and then what I watched from inside Mark's truck as his 12.5" tires kept him off the wall preventing body damage.
3.)No one ever said body damage doesn't come with the territory of wheeling. And part of wheeling is challenging your truck and overcoming obstacles. The risk of body damage is always there, but the fact is wider tires help prevent body damage in a lot of cases where it would be inevitable with skinnys no matter the persons skill or if they had a winch.
It is the same principal with people that run rock sliders that stick out past the body. They use them in many cases to keep the body of the truck up off rocks, mud walls etc.
So next time any of you come up to Uwharrie to wheel with us we will swap and you can run my skinny 34x9.5s. You can go through the exact same obstacles I got body damage on and we will see how skill and a winch gets you out of it. <img src="/forums/images/graemlins/baby.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: DRaider90] #955605 07/27/09 12:37 AM
0778drz110 Offline
What are you waiting for? You said you would post pics <img src="/forums/images/graemlins/smile.gif" alt="" />
inspiration:
http://www.4x4wire.com/forums/showf...;amp;page=0&fpart=1&vc=1
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: 0778drz110] #955606 07/27/09 01:00 AM
0778drz110 Offline
I'm so awesome <img src="/forums/images/graemlins/lol.gif" alt="" />
screwed:
not so screwed:
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: 0778drz110] #955607 07/27/09 01:01 AM
hochkis Offline
screwed:
not so screwed:
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: 0778drz110] #955608 07/27/09 01:47 AM
K_Raider Offline
That is funny stuff. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Thanks for the laugh.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: K_Raider] #955609 07/27/09 02:37 AM
sparkem Offline
Yes the tires sticking out do help. They saved my fenders a few times.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: 0778drz110] #955610 07/27/09 03:04 AM
ncdieselwrench Offline
screwed:
not so screwed:
This picture is great to prove my point. The width of the tire is not the tool that is preventing the damage but the added distance that it adds inbetween the object and the body. I can run a 2 inch wide tire three feet from the edge of the axle, or I could run it inside the fender not producing any protection buffer. That and that alone is what is saving you body from damage not whether or not the tire is 2 inches or 2 feet wide. You could mount a wider tire onto a vehicle and adjust the backspacing so that the tire does not protrude from the body at all. So if you want to prevent body damage go buy wheel spacers, or different backspaced rims, not wider tires. The rule of thumb I've followed is for every inch you lift it up, you need to make it atleast an inch wider. Besides Eli you need to bury those superwinches some.
1993 Chevy Suburban 2500- Tow Rig
1991 Mitsubishi Montero LS LWB
SR Parts:
Rear Axle
Coils
Trailing Arms
Front Calipers
and soon to have UCA's and idler arm.
Dual Bouncies
Air Lift Airbags
Aisins
33x12.50x15 Custom Grooved TSL's
Body lift in the near future.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6494 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-20 15:29:11 UTC
