Re: Minor hesitation Starting [Re: bombardj1] #957836 08/09/09 02:39 AM
Hydra747 Offline OP
this is a dumb ? but are you giving it any gas when you are trying to start it ? if you are you might be flooding it just a little, try this just turn the ket on but not all the way just to energize the system for about 2 seconds then turn the key and see if it will start with out giving any gas, then you can give a little gas. just a thought.
John
No Bomber!
I don't do this...........
Thanks for helping me John as always my friend......
Checking for V-Leaks like Nukey Said........
Re: Minor hesitation Starting [Re: Hydra747] #957837 08/09/09 11:24 PM
Hydra747 Offline OP
Today was rather mild in weather for Texas like 95f.....So I reluctantly made the effort to re-examine all the lines. I took off the intake and disconnected the charcoal box too. I happened to notice the clamp off........... on on line (closest to the radiator) from the charcoal box, but the tube seemed to be able to move easily with my hand.
I figured since I was on a roll I would dis-assemble the rest (intake also)for a thorough inspection. All the other lines were fine.
I then went (in another vehicle) to Advance Auto and ask for a pressure vacuum gauge....They looked at me like I was nuts. I commenced to fill them in on what was going on and the manager swaid that a faulty spark plug could cause p0171 as well as starting issues......
Fine. I bought 4 autolite dual spark plugs, gassket sealer, anti-seize and the electrical grease stuff for the top connectors of the spark plugs.
I took out the spark plug in bank 1 and it was dry but very very burnt on the plastic area and very gray in color on the spark side with obvious wear. The same for the other 3 but at least the gaps were still .44
After re-assembly (and battery re-connection) I also sealed off the air temp sensor on the rubber top of the K&N with gasket sealer vs. using Teflon tape for the threads.
Aside from struggling with the car alarm.......It Started Up Very Very nicely and idled extremely well.
Took it for a test drive for about 50 miles it ran excellent and guess what?????????????
NO CODES!!!!!!!!!!!!!
Check ur freakin' spark plugs!
Thanks Ya'll for all of ur help.<img src="/forums/images/graemlins/kewl.gif" alt="" />
Could have prevented buying a new o2 sensor, fuel filter, fuel pump, starter, Idle controller, new battery ect......
But I prolly needed to get those in anyway sometime down the road (pun intended)! <img src="/forums/images/graemlins/lol.gif" alt="" />
Thanks again.
Mikey
Re: Minor hesitation Starting [Re: Hydra747] #957838 08/10/09 03:08 AM
londart Offline
glad it helped you but the plugs were the first thing i tried as well as cleaning the maf and changing coolant temp sensor and that was when i still had stock airbox, have since changed tps and fuel filter but no help...its not a big deal to me to have to crank it over two or three times but i dont want it to get any worse before i figure out what it is...thought about O2 sensor but thats alot to throw away when im not even throwing a code
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: Minor hesitation Starting [Re: londart] #957839 08/10/09 03:59 PM
Hydra747 Offline OP
Just an idea........
Check ur spark plugs again (gap, connection etc).....
And BTW certain plugs WILL NOT work on the sportages...at least as in my experience.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Minor hesitation Starting [Re: Hydra747] #957840 08/10/09 05:59 PM
catman25 Offline
can we have a list of confirmed working or a list of confirmed plugs that give issues , Im working with a p0171 and i got it after changing plugs , So Im going to get another set and check , Think i might get ngk oems .
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: Minor hesitation Starting [Re: catman25] #957841 08/10/09 11:41 PM
Hydra747 Offline OP
Hey Catman 25,
U could have hit ur pcv when u were doing ur spark plug job (backtracking to when ur problem started).........
Just a thought that I got today after getting off of work....
Did u spray intake cleaner to see if idle changed at all (to locate leak)?
MAF sensor OK?
I know the feeling of being frustrated.....was almost going to go to the dealership.....cause I got so SICK of that code (like londhart was)..... <img src="/forums/images/graemlins/angry.gif" alt="" />
And I do know that if u have some vacuum leaks the code reader will actually say "Vacuum Leak" like in the case of a missing gas cap.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6201 MB (Peak: 0.7094 MB) Data Comp: Off Server Time: 2026-06-07 10:35:32 UTC
