Page 1 of 5 1 2 3 4 5
Making my own snorkel, #960123 08/23/09 02:15 PM
Mudraider Offline OP
None listed for the 2.6 Raider, so I am making my own. It's not as slick as one of the ABS ones, but it will be functional. I love having hillbilly friends who "with a cuttin torch and a stick welder we can fix anything" mentality. [Linked Image] [Linked Image] [Linked Image]
Re: Making my own snorkel, [Re: Mudraider] #960124 08/23/09 05:37 PM
ForcedAir_Montero Offline
I like the idea! (there is actually one listed for gen 1 montys, but...)
My only thought is that it looks very small. The aftermarket ones are quite a bit larger. Is the motor going to be able to pull enough air through that small tube for the length?
Nice job <img src="/forums/images/graemlins/cheers.gif" alt="" />
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Making my own snorkel, [Re: Mudraider] #960125 08/23/09 06:07 PM
CapnCrunch Offline
None listed for the 2.6 Raider...
Try here. The part number is SS20HF. I have one on my '88 with a 2.6...
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Making my own snorkel, [Re: Mudraider] #960126 08/23/09 08:30 PM
LRJ4x4 Offline
You need to run 3 inch pipe to have enough airflow.
Re: Making my own snorkel, [Re: LRJ4x4] #960127 08/23/09 08:41 PM
Hmmm. Great. It's 2 1/4" muffler tubing. I fitted it to the hose from the air cleaner to the fender. I'm wondering why does it have to be 3" tubing?
Re: Making my own snorkel, [Re: Mudraider] #960128 08/23/09 09:08 PM
There are friction losses in the tube, and turbulence in the crimp bends. Those lead to flow losses, which lead to power losses. I'd use 3" (almost twice the cross section area) abs plastic tube, maybe sch20 or thereabouts wall thickness. Much slicker than steel, too.
Gonna be tough to use a larger hole saw on that hole unless you mount a block of wood to center the pilot drill.
Re: Making my own snorkel, [Re: fasteddy] #960129 08/30/09 05:17 AM
Well' it's made and going to give it a shot. It's all stock' and I've seen some 6 cylinder Rangers playing in the mud with the same set-up so I think for my application it will work. I'll post some pics tomorrow.
Re: Making my own snorkel, [Re: Mudraider] #960130 08/31/09 03:09 AM
I hope posting these pics works. The first couple should show the mounting brackets with nutserts, then some pics with the snorkel mounted. I still will mount a bracket on the roof pillar, plus one in the engine compartment right before the intake hose connection. I hope its sturdy enough. If the nutserts give me any flex' I'll mount the brackets with nuts and fender washers from inside the engine compartment. [img][image]http://i598.photobucket.com/albums/tt64/fastfoodvw/snorkel1.jpg[/img][/image]
Re: Making my own snorkel, [Re: Mudraider] #960131 08/31/09 03:23 AM
Here is the first bracket mounted, the Nutserts are good and tight, the bracket feels fairly stiff on the fender.
This is the 2nd brackets holes with the nutserts installed
[img][image]http://i598.photobucket.com/albums/tt64/fastfoodvw/snorkel3.jpg[/img][/image]
Just to see what it will look like, still a couple more brackets needed.
[img][image]http://i598.photobucket.com/albums/tt64/fastfoodvw/snorkel4.jpg[/img][/image]
Re: Making my own snorkel, [Re: Mudraider] #960132 08/31/09 03:39 AM
StockRaider Offline
pretty neat looking ghetto fabbing there <img src="/forums/images/graemlins/kewl.gif" alt="" />
Glad I decided against Advance Auto mirrors. <img src="/forums/images/graemlins/scared.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6448 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-06-01 13:28:30 UTC
