Re: front end noise
#960229
08/28/09 01:21 AM
sure, I need to get it done so if you have a pic it would be appreciated
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress. 2011 Kia Forte EX
Re: front end noise
[Re: homerdog]
#960230
08/28/09 02:04 AM
started mine tonight got them out with ease the rotor bracket was different story [pre-soak recomended]6 foot pry bar and a hammer took care of it and the rest went smooth and while im there a couple wheel studs are getting replaced. i will take a couple photos of it going back together and with it already apart, got ahead of myself when taking apart and no photos
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: front end noise
[Re: homerdog]
#960231
08/28/09 07:04 AM
This is not an actual photo or anything...I was not doing that back then...not really doing now either...lol Its all I had to go by when I did this. Just sits right in the back of the knuckle. Thought I had one somewhere....I will have a look and if I find it I will throw it up here. ![[Linked Image]](http://i578.photobucket.com/albums/ss227/ijag/NeedleBearing.jpg)
Re: front end noise
#960232
08/28/09 10:17 PM
well bearings are done and my noise is still with me and the bearings have nothing to do with the half shaft so i should have known better because they dont even make contact with each other. they needed changed anyway pretty easy job. next question is what does the half shaft ride on inside the spindle? didnt take that apart yet until i get the axle so i guess that will be next weekend project 4x4 still works so if it aint broke wheel thats what im going to do.
Re: front end noise
[Re: jays2001]
#960233
08/29/09 12:39 AM
The Needle Bearing holds the inner part of the half axle when it is all the way in, and the hub holds the outer part of it. If your needle bearing is gone it will make noises and you will not be able to figure it out until you take it all apart and look at it. I was so confused with this myself until I got it apart and saw the shape of the bearing....Now and then it made no noise...but when it did make noise it was not nice.
Check the needle bearing.
Re: front end noise
#960234
08/30/09 06:27 PM
i started getting this problem yesterday when i locked the hubs...First time i hear this but don't sound like a very nice noise....I'll be taking mine apart through the week. I'll try to take some pics and post as i go.
2001 sporty, tj rear springs with rav4 shocks, ford alloys machined centers with 30x9.5x15, front spacers. more upgrades to come.
Re: front end noise
[Re: budicexxx]
#960235
09/01/09 12:22 AM
i got the needle bearing fri and only 9.81 per side from the dealer, shockingly cheap for a dealer part.doing this weekend after i get the half shaft bought. hope this is it becase if that doesnt fix it im totaly lost on what it could be because after that the front end on that side has been pretty well rebuilt.
Re: front end noise
[Re: jays2001]
#960236
09/01/09 01:18 AM
i got the needle bearing fri and only 9.81 per side from the dealer, shockingly cheap for a dealer part.doing this weekend after i get the half shaft bought. hope this is it becase if that doesnt fix it im totaly lost on what it could be because after that the front end on that side has been pretty well rebuilt. Hope its that cheap here in canada...I'm gonna call tomorow
Re: front end noise
[Re: budicexxx]
#960237
09/01/09 05:06 AM
17 bucks in Vancouver I think it was. I bought a few of them...have extras in the truck...lol Also....I just remembered.....I replaced the half shaft on the drivers side before I knew about the needle bearing...Expensive way to trouble shoot. I still have that half shaft as there is nothing wrong with it after all. Did I ever feel like a tool after that....lol
Hope it all goes good for you guys.
Re: front end noise
#960238
09/01/09 12:44 PM
Just called kia and they are 15.94 plus tax here. Like said previously strange they are not that expensive. Now just have to find some numbers for the inner and outer as i will try to these at the bearing store...If anyone has any numbers for these would help alot. This is for a 01 sportage EX.
