Rating: 3
Page 5 of 7 1 2 3 4 5 6 7
Re: front end noise [Re: budicexxx] #960259 09/07/09 01:34 PM
homerdog Offline
Do I need to separate the hub and rotor from the knuckle?
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: front end noise [Re: homerdog] #960260 09/07/09 07:16 PM
homerdog Offline
Any suggestions on getting the nut off the control arm?
2011 Kia Forte EX
Re: front end noise [Re: homerdog] #960261 09/07/09 09:33 PM
homerdog Offline
Any suggestions on how to get the remains of the bearing out?
2011 Kia Forte EX
Re: front end noise [Re: homerdog] #960262 09/07/09 09:38 PM
jays2001 Offline OP
i used a flat csrew driver that i hit with a file to make it have a better edge to get between the wall and bearing race and go around it all the way then cut it in half poped right out.
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: front end noise [Re: jays2001] #960263 09/07/09 09:41 PM
homerdog Offline
I'll try that, been using a chisel and no luck, been at it for 5 hours now trying to get the thing fixed and the bearing wasn't in that bad of shape so it's probably something else.
Re: front end noise [Re: homerdog] #960264 09/07/09 11:12 PM
homerdog Offline
oh well, that was a waste of a perfectly good afternoon
2011 Kia Forte EX
Re: front end noise [Re: homerdog] #960265 09/08/09 12:02 AM
your needle bearing was in good shape?
Remeber there is another one...lol
Re: front end noise #960266 09/08/09 12:36 AM
budicexxx Offline
There is no need to remove the tie rod. I didnt and for the race of the bearings one of the bearing has a bigger lip than the other knock that one out first with a hammer and a punch then have some one smooth sailing for the other one. The needle bearing i tapped it with a sharp chisel and it broke right out.
2001 sporty, tj rear springs with rav4 shocks, ford alloys machined centers with 30x9.5x15, front spacers. more upgrades to come.
Re: front end noise #960267 09/08/09 01:02 AM
homerdog Offline
Thing is that I can lock in the right side and hear the noise. If I lock in just the left side I don't hear it. Sounds like I'm hitting a speed bump. Maybe the halfaxle is shot, I'll try that next, it's got a tear in the boot anyways.
2011 Kia Forte EX
Re: front end noise [Re: homerdog] #960268 09/08/09 01:35 AM
jays2001 Offline OP
that was the samething with mine and it was the needle bearing
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6378 MB (Peak: 0.7281 MB) Data Comp: Off Server Time: 2026-06-17 01:40:14 UTC
