Page 1 of 3 1 2 3
95 SR with white smoke maybe the valve stem seals ??? #960410 08/24/09 11:43 PM
tyty Offline OP
I pick 95" sr with 200k that smokes all the time. Is it the valve stem seals?
If so, dose any one know how much a shop would charge to change them or should I just get the head's rebuilt.
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: tyty] #960411 08/24/09 11:50 PM
White smoke = coolant. Blue-ish smoke = oil.
Does the smoke smell sweet, like coolant? Bluish smoke would lead me to start with the valve stem seals, yes. Coolant smoke would have me looking farther internal.
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: JohnnyBfromPeoria] #960412 08/25/09 12:34 AM
tyty Offline OP
Here some pic of what it look's like...
Thanks for the help
http://i97.photobucket.com/albums/l217/tyty1313/95%20montero/IMG_4799.jpg
http://i97.photobucket.com/albums/l217/tyty1313/95%20montero/IMG_4796.jpg
http://i97.photobucket.com/albums/l217/tyty1313/95%20montero/IMG_4802.jpg
<a href="http://s97.photobucket.com/albums/l217/tyty1313/95%20montero/?action=view&current=IMG_4796.jpg" target="_blank"><img src="http://i97.photobucket.com/albums/l217/tyty1313/95%20montero/IMG_4796.jpg" border="0" alt="Photobucket"></a>
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: tyty] #960413 08/25/09 01:17 AM
StockRaider Offline
does it smoke pretty much right away? does it burn constantly? or only when your at a light and hit the gas? if your losing coolant thats a headgasket. If your burning oil, its either valve seals or possibly bad rings.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: StockRaider] #960414 08/25/09 01:43 AM
Worse after prolonged idle?
Looks bluish to me, like oil. I vote valve stem seals.
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: fasteddy] #960415 08/25/09 03:31 AM
1
1986powerram50 Offline
From my experience 200k is about the time the headgaskets go. Hope you enjoy replaing them on a 6g74 DOHC I know I sure have :lol: Watch out tho it might drive you to <img src="/forums/images/graemlins/cheers.gif" alt="" /> ing
--keRby
Ad Inexplorta
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: 1986powerram50] #960416 08/25/09 05:14 AM
It's hard to tell from the pictures, isn't it? Could use the smell test, plus the above advice about losing coolant. Is the oil staying clean, or is it getting chocolaty-milk-looking?
I'd sure hope it's valve stem seals.
Still, I don't know how much a shop would charge to replace them, sorry.
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: JohnnyBfromPeoria] #960417 08/25/09 05:28 AM
tyty Offline OP
coolant look's good -green
oil look's clean
Dont know much more pick it up for $350
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: tyty] #960418 08/25/09 05:49 AM
StockRaider Offline
If your coolent is clean and your not losing any. As well as your oil being clean, I would take a shot at saying its either valve stem seals (easy replacement if your mechanically inclined) OR bad rings on a cylinder. Check for fouling plugs. I notice most valves seals that go bad are on the exhaust side so you don't really foul out plugs. But if your fouling a plug it could be a bad ring.
Richard E
1983 Honda XL600R
Re: 95 SR with white smoke maybe the valve stem seals ??? [Re: StockRaider] #960419 08/25/09 08:14 AM
tyty Offline OP
Would a compression test tell me bad rings or ??
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6414 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-11-03 09:29:34 UTC
