Raider V6 Idler pulleys? #960666 08/26/09 04:33 AM
mike71800b Offline OP
I just recently got an 89 v6 raider. The serpentine idler pulleys under the alternator are whirring, but I don't see these idlers at any of the usual parts sites nor rock auto.
Anyone got a source for these, or perhaps is there a standard size bearing that can be pressed in the pulley?
Thanks
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: Raider V6 Idler pulleys? [Re: mike71800b] #960667 08/26/09 04:40 AM
haztoys Offline
MY 89 is running on 89 dodge caravan v6 idlers .and a few washers in the back ..Napa brand ,,can get you a number if you cant find them ..
Re: Raider V6 Idler pulleys? [Re: haztoys] #960668 08/26/09 04:45 AM
StockRaider Offline
I have bad idlers too, but I am going to take one of mine off and see if I can match up with a Ford vehicle product. I am hoping Mustang ones match so I can order Billet pulleys for my Montero. <img src="/forums/images/graemlins/mrt.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Raider V6 Idler pulleys? [Re: StockRaider] #960669 08/26/09 05:01 AM
haztoys Offline
"napa 38042 nbh backside idler pulley" ...is what my paper work says ..
Re: Raider V6 Idler pulleys? [Re: haztoys] #960670 08/26/09 06:52 AM
89Montiero Offline
My mechanic just replaced mine. I could be wrong but I think he got the parts from Mitsubishi.
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's
2005 Mitsubishi Montero Limited 3.8 V6
2011 Subaru Impreza Outback Sport
Re: Raider V6 Idler pulleys? [Re: 89Montiero] #960671 08/26/09 07:20 AM
4ePikanini Offline
Is it these ones?
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Raider V6 Idler pulleys? [Re: 4ePikanini] #960672 08/26/09 05:53 PM
Goodyear makes a good one, too. Search my username and "goodyear" and you should get a part#, or look at FrankR's supercharged v6 post for the billet pulleys he got. The goodyears require 4-5 flat washers for proper spacing from the bracket...
Re: Raider V6 Idler pulleys? [Re: fasteddy] #960673 08/27/09 05:35 AM
Montero_Jim Offline
Try your Dodge dealer, too. I bought a set for my Montero about 3 years ago. No problem and they were cheaper than the Mitsu dealer, who really didn't want to talk to me anyway.
1987 Raider
1991 Montero LS
Nipomo, CA
Re: Raider V6 Idler pulleys? [Re: Montero_Jim] #960674 08/27/09 08:24 AM
joestruck Offline
Goodyear Gatorback, that is the name they use on all the belts and belt-related hardware., I just threw out the box last week, I put pix up when I did it...That was about a year ago.
Re: Raider V6 Idler pulleys? [Re: joestruck] #960675 08/27/09 04:05 PM
JAVYPRO Offline
If not contact hazy_daze (Larry), he got them for my wife uncle and they are working like a dream. They are so easy to replace that will take you just 5 minutes to do.
You only need a 12mm for the adjustment bolt and a 14mm for the pulley's nut.
Loose the adjustment bolt and remove the pulley's nut, place new pulleys in and bolt them back in then the adjustment bolt.
Done, it is that easy.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6370 MB (Peak: 0.7441 MB) Data Comp: Off Server Time: 2026-05-31 14:16:38 UTC
