Re: In the case of the Mitsubishi 3.0L V6.... [Re: FrankR] #961503 09/03/09 03:26 PM
Kevin C Offline
Just remember that the block needs just as good a surface finish to seal to the MLM gaskets.
Kevin
Re: In the case of the Mitsubishi 3.0L V6.... [Re: Kevin C] #961504 09/03/09 06:16 PM
FrankR Offline
That's right.
The OE composite gasket works well, even with a moderate amount of boost, and it can provide a measure of sealing for etched decks that the MLS gasket cannot do - very important if heads are replaced without doing a complete rebuild including a deck cut.
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: In the case of the Mitsubishi 3.0L V6.... [Re: FrankR] #961505 09/03/09 09:33 PM
Kevin C Offline
I knew you knew that .... Just making sure everyone else did.
Back to house painting and shingling.
Kevin
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-09 23:40:12 UTC
