Gen 1 Montero LS - Windshield Frame Rust #962043 09/05/09 01:14 AM
tdf_46 Offline OP
Yesterday the Glass Doctor guy came to my place to replace the cracked windshield. He left with my old cracked shield and I was left with none.
Reason: The PO had put silicone sealant around the rubber gasket. That trapped the moisture behind the seal. Result - RUST. <img src="/forums/images/graemlins/angry.gif" alt="" /> Had some rust through in the corners and a couple other spots. Now I have to repair that mess. How common is it to have that gasket start to leak such that someone would think they needed to add sealant.
No sheet metal rust anywhere else on the rig. Vehicle originally a central CA rig.
Started grinding away the rust spots last night. Going to get to use my limited sheet metal patching skills as there are some holes there for sure!
tdf_46 (Tom)
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: tdf_46] #962044 09/05/09 01:29 AM
Happened to me on my first Raider, too. I had applied clear silicone to keep the thing from leaking in on the passenger side. Luckily, mine didn't get to the stage that the metal needed patching, but the glass guy did apply that POR stuff on the metal after we cleaned it up a bit.
It does seem that a few others have complained about leaks there as well.
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: JohnnyBfromPeoria] #962045 09/05/09 01:46 AM
tdf_46 Offline OP
If there is anything to be learned here guys and gals I guess it is to not use silicone where rubber meets sheet metal. The glass man said silicone actually is a rust promoter when in contact with steel! Additionally that moisture needs to be able to escape as water vapor when it gets the sun on it.
tdf_46 (Tom)
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: tdf_46] #962046 09/05/09 03:22 AM
sasnydley Offline
Actually My truck has that problem. Event thought it looks good still.
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: sasnydley] #962047 09/05/09 03:51 AM
What's the solution? Break your windshield so the insurance company replaces it, along with the seal? Ultimately, that's what did it for me. Gotta thank that tree branch!
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: JohnnyBfromPeoria] #962048 09/06/09 03:54 PM
Y
yankee7809 Offline
My generation 1 did it badly with water building up in the driver's side floor board. My gen 11 is now leaking after a glass company replaced a cracked windshield.
1995 Montero LS, KYBs, Michelin 31s. 2009 Kia Borrego EX. (Wife's wheels.)
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: yankee7809] #962049 09/07/09 12:23 PM
joestruck Offline
Shoot, that makes me nervous. I have this "spot" under the A pillar.. soon after this pic, I used flowing silicone because if I parked facing down hill, even slightly, the morning dew would drip in.
Re: Gen 1 Montero LS - Windshield Frame Rust [Re: tdf_46] #962050 09/07/09 03:47 PM
RobCambo Offline
My series 1 is left hand drive, and has a leak in the upper passenger corner of the windshield. The water tends to quickly run in when I go around a corner rather than drip or run when standing or moving in a straight line. No rust showing. Luckily there's an 8 month "dry season" here with no rain at all... <img src="/forums/images/graemlins/smile.gif" alt="" />
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Windshield Frame Rust Repair = Welding Challenge [Re: RobCambo] #962051 09/26/09 06:19 AM
tdf_46 Offline OP
Well I started the sheet metal repairs. Cutting out the bad areas and welding in patches. I'm finding welding sheet metal to be quite a challenge. Getting the wire feed and voltage just right is tricky! Read a few tips online tonight so maybe tomorrows attempts will go better.
tdf_46 (Tom)
Re: Windshield Frame Rust Repair = Welding Challenge [Re: tdf_46] #962052 09/28/09 05:38 PM
cdl1701 Offline
Yep my Raider leaked pretty good also on the driver side. I had a windshield place try 3 times to get it to seal but I ended up just using clear silicon to stop it.
88 Montero, 2.6 Black
PHP: 7.4.33 Page Time: 1.237s Queries: 15 (0.005s) Memory: 0.6318 MB (Peak: 0.7404 MB) Data Comp: Off Server Time: 2026-06-22 15:11:19 UTC
