Re: Transmission Key Crushed [Re: blinkerbox] #962497 09/09/09 07:05 AM
StockRaider Offline
you might be able to get away with swapping pump and TC but for the cost of them both from a JY it might be cheaper to grab the whole trans.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Transmission Key Crushed [Re: StockRaider] #962498 09/09/09 01:59 PM
blinkerbox Offline OP
I can get a tc for $25 and then the pump for about $10, whereas a transmission would cost $99. I'd be more inclined to get the whole thing if I damaged more than just the pump and/or had room to store it. Something I won't be able to tell until I pull the front cover off. Anyone ever replaced the pump in the transmission?
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962499 09/09/09 02:14 PM
haztoys Offline
If your going to pull the pump ... You will be pulling the "input shaft " and the "pump"... You must stand the trans in its end with the pump facing up ... If you do not shims and plates "could" drop out of place that are deep down in the trans ... Try that it will help .. If it on its side as in the truck ...You pull the shaft shims may drop think about it ..???
David
Hazardous Toys inc
Re: Transmission Key Crushed [Re: haztoys] #962500 09/09/09 02:24 PM
Good to know, haztoys. In that case pulling an entire trans might be the way to go, just to avoid the hassle.
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962501 09/09/09 11:45 PM
StockRaider Offline
Exactly <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6131 MB (Peak: 0.6780 MB) Data Comp: Off Server Time: 2026-06-07 05:01:19 UTC
