Re: Transmission Key Crushed
[Re: blinkerbox]
#962497
09/09/09 07:05 AM
you might be able to get away with swapping pump and TC but for the cost of them both from a JY it might be cheaper to grab the whole trans.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#962498
09/09/09 01:59 PM
I can get a tc for $25 and then the pump for about $10, whereas a transmission would cost $99. I'd be more inclined to get the whole thing if I damaged more than just the pump and/or had room to store it. Something I won't be able to tell until I pull the front cover off. Anyone ever replaced the pump in the transmission?
'91 RS, '93 SR
[Re: blinkerbox]
#962499
09/09/09 02:14 PM
If your going to pull the pump ... You will be pulling the "input shaft " and the "pump"... You must stand the trans in its end with the pump facing up ... If you do not shims and plates "could" drop out of place that are deep down in the trans ... Try that it will help .. If it on its side as in the truck ...You pull the shaft shims may drop think about it ..???
David
Hazardous Toys inc
[Re: haztoys]
#962500
09/09/09 02:24 PM
Good to know, haztoys. In that case pulling an entire trans might be the way to go, just to avoid the hassle.
'91 RS, '93 SR
[Re: blinkerbox]
#962501
09/09/09 11:45 PM
Exactly <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6140 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-09 21:50:50 UTCValid HTML 5 and Valid CSS
