Page 2 of 3 1 2 3
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: Lester] #962542 09/12/09 02:30 AM
KrzyDav Offline
Man , your not messin' around,,,great truck <img src="/forums/images/graemlins/kewl.gif" alt="" />.
Everbody look at your axle flanges and see if the 9 and 9.5 both have "80" on them...
Do all 9" and 9.5" have a different driveshaft end?
Or,,,maybe there is another way to tell which axle he has.
You can tell him and me cause I'b like to know, too.
dave h.
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: KrzyDav] #962543 09/12/09 04:34 AM
How about tackling it from another end. I always thought it was possible to to reline brake shoes. Any place out there still do that? No reason not to use riveted linings, either, since it's a grab and hold brake mostly.
I'm still trying to figure out how Lester's wore out. Unless they were almost too tight and dragging.
Lester (how ya been, friend?), have you actually eyeballed the shoes, or just inferred "worn out" from lever stroke length?
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: fasteddy] #962544 09/12/09 02:13 PM
hazy_daze Offline
Those are awesome Lester. I'm going to check to see if we can get them here in the States.
Frank, I was just tryin to be cooler than I normally am.... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm thinkin along the same lines as Eddy. Unless you're using the E brake to slow yourself, I can't see how it would wear out, if properly adjusted of course.
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: fasteddy] #962545 09/12/09 04:58 PM
L
Lester Offline OP
Hi fasteddy
All's well. Recently just changed out my stock Starion oil cooler lines cos one of them was leaking. Planning for a top end overhaul but don't have a time line yet.
2 weeks back, there was a leak with one end of the axle shaft. Got it out changed the seal and discovered that the brake shoes were near to reaching the rivets. Thought I had better get them changed.
How are things on your end? All well...?
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: KrzyDav] #962546 09/12/09 04:59 PM
L
Lester Offline OP
I think the 9.5" has 81 and 82 on the ends.
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: hazy_daze] #962547 09/12/09 05:10 PM
Grasscat Offline
I use mine all the time when coming off a steep down hill while wheeling.
Michael j
TreadLightly! Trainer
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: hazy_daze] #962548 09/12/09 05:38 PM
L
Lester Offline OP
Hi Hazy_daze
When I got the axle, the wear is already at the rivets.It's been like that for the last 4 years. Tot I will get them changed in case my drum get scrapped by the rivet and worst damage occurs.
Besides, I dare not adjust the shoes too near to the drum surface in case there might be any rubbing. I am on almost 7 to 8 clicks to engage a full lock. At full lock, there is still slight movement.
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: OldColt] #962549 04/14/10 11:01 AM
L
Lester Offline OP
Hi Charlie
With regards to the parking shoes for the locker axle, I am still unsuccessful in getting the correct set. I ordered a set from Carparts.com and they turned out to be for the stock drum axle.
Can anyone please point me to the correct source for these pads? Thanks.
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: Lester] #962550 04/14/10 08:47 PM
JAVYPRO Offline
Hey Lester, that hood with the scoop is that an aftermarket or was it oem with your rig.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Looking for rear parking brake shoes for locker axle with disc brake [Re: JAVYPRO] #962551 04/15/10 01:41 AM
L
Lester Offline OP
It is a hood from the diesel Gen 1.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6457 MB (Peak: 0.7514 MB) Data Comp: Off Server Time: 2026-06-17 11:38:29 UTC
