Page 3 of 3 1 2 3
Re: I have a question on installing my Gen2 upper control arms. [Re: KrzyDav] #962601 09/20/09 12:02 AM
V
vr4 Offline
for future reference....put a floor jack under the LCA to take the load off the UCA so you can pull them without loosening the torsion bar.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: I have a question on installing my Gen2 upper control arms. [Re: vr4] #962602 09/22/09 07:43 PM
KrzyDav Offline OP
Done!
I didn't reindex , but for going higher I would diffenently recommed it.
I set mine at 3 3/4 inch measure on lower bumper pad, from metal to meta.
Anybody using Gen 1 brake hoses and Gen 2 mounts
dave h.
Re: I have a question on installing my Gen2 upper control arms. [Re: KrzyDav] #962603 09/24/09 03:55 AM
KrzyDav Offline OP
Sorry about the unfinished post...
Library auto cut off.
I retained my newish Gen 1 brake hoses.
I put my gen 1 brake hose brakets back on the gen 2 arms. Using gen 2 brakets -the upper brake hose gets pulled pretty hard when the upper bump stops are trimed to half hiegth.
Anybody with the same setup should double check the hoses.
dave h.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6564 MB) Data Comp: Off Server Time: 2026-06-20 18:58:36 UTC
