Re: I have a question on installing my Gen2 upper control arms.
[Re: KrzyDav]
#962601
09/20/09 12:02 AM
for future reference....put a floor jack under the LCA to take the load off the UCA so you can pull them without loosening the torsion bar.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
[Re: vr4]
#962602
09/22/09 07:43 PM
Done! I didn't reindex , but for going higher I would diffenently recommed it. I set mine at 3 3/4 inch measure on lower bumper pad, from metal to meta. Anybody using Gen 1 brake hoses and Gen 2 mounts
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#962603
09/24/09 03:55 AM
Sorry about the unfinished post... Library auto cut off. I retained my newish Gen 1 brake hoses. I put my gen 1 brake hose brakets back on the gen 2 arms. Using gen 2 brakets -the upper brake hose gets pulled pretty hard when the upper bump stops are trimed to half hiegth. Anybody with the same setup should double check the hoses.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6015 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-06-18 05:47:52 UTCValid HTML 5 and Valid CSS
