Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: some of us want a LSD for rear [Re: DennisThompson] #963217 09/18/09 01:25 PM
Everet Offline
Can't find a stock Kia LSD, Try RX7.
The ones I was talking about were for the front.
Dennis, do you have other information?
Re: some of us want a LSD for rear [Re: Everet] #963218 09/18/09 05:27 PM
DennisThompson Offline
Most Miata's fit the front, Miata's with Torson LSD and turbo RX7's fit the rear. Look for early 90s and do some research and check ring gear size and spline count before you buy. Go back in the arcives a ways, this has been gone through a few times but I find new thing ever time I research more.
Dennis
What do I have? [Re: DennisThompson] #963219 09/19/09 10:55 AM
2002_Sporty Offline
I don't know if I have a LSD or not in my 2002 Sporty.
I know only one tire spins in snow, mud and up hills.
How do I go about finding out if I have one in the rear?
If I don't have one. There is a possibility that I can order one for an older Miata or RX7 to put in mine?
Excuse my ignorance please.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: What do I have? [Re: 2002_Sporty] #963220 09/20/09 04:09 AM
bombardj1 Offline OP
raise the rear wheels put in neut. and spin the rear right wheel forward both should move forward, if not it's not a lsd,
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: some of us want a LSD for rear [Re: DennisThompson] #963221 09/20/09 06:57 AM
Dennis what is the ring gear size on a 2001 sporty, won't the ring gear off our rear ends bolt up to the rx7 lsd ? do you know off hand the dia of the side bearing that mounts up to the carrier assy. ?
Re: some of us want a LSD for rear [Re: DennisThompson] #963222 09/20/09 07:19 AM
Dennis do you know the dia. of the rear end of the diff. both sides, I see that RX7 have a open barrled bearings and the kia's are closed, the RX7's bearing will have to be removed. you know after looking at drawings of the sportage is that little gear-set bolted to the LSD and being turned by a pinion gear. ok guys please don't hound me about what I am thinking, but I do need the measurements , thanks again Dennis
Re: some of us want a LSD for rear [Re: Everet] #963223 09/20/09 01:29 PM
Nukeiridium Offline
I was reading around about LSD's. I saw some posts about people using Sportage LSD's in a Honda S2000.
There are lots of LSD's out there for the S2000.
Anyone know enough to tell whether the S2000 LSD would fit in the Sportage?
There are some S2000 LSD's on Ebay, some for as cheap as $350. Unfortunately they are helical LSD's so, not as good as clutch type LSD for offroading right?
There are others but they are like $800 or something.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: some of us want a LSD for rear [Re: Nukeiridium] #963224 09/25/09 06:07 AM
It wouldn't surprise me, most Honda's are FWD so they had to source a dif somewhere for a RWD. Again, Research before you buy anything. Also you want to find either a clutch type or a Torsen for off road. The Ranger FX4 level IIs use a Torsen and they seem to work great.
Dennis
Re: some of us want a LSD for rear [Re: DennisThompson] #963225 09/25/09 06:23 AM
Everet Offline
The S2000 will fit the front. Guys buy the Sportage front ring and pinion for the lowest gears available for the S2000.
Re: some of us want a LSD for rear [Re: Everet] #963226 09/26/09 12:10 AM
Hydra747 Offline
I found a rear LSD carrier for $725 at KiaPars.com
Way to Buku!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6432 MB (Peak: 0.7516 MB) Data Comp: Off Server Time: 2026-05-29 23:41:42 UTC
