Page 1 of 9 1 2 3 4 5 6 7 8 9
some of us want a LSD for rear #963207 09/14/09 02:00 AM
bombardj1 Offline OP
some of have 2wd and some 4wd, but have none lsd carriers and are tired of sliding on the road because of only 1 rear wheel grabbing the road and on have a source for LSD's in there area's like pice-a-parts etc. that they are willing to check out. we have tried in our areas and they are not to be had.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: some of us want a LSD for rear [Re: bombardj1] #963208 09/14/09 02:12 AM
Hydra747 Offline
I as well would like to know the current sources for obtainment of rear axle LSD. I have searched for quite a while and came up with zero!
Stock for sure. Any one know?
If so then please let All of Us Know!
Thanks,
Mikey
Re: some of us want a LSD for rear [Re: Hydra747] #963209 09/14/09 02:24 AM
londart Offline
you might try the national locator for junkyards the website is car-part.com ..... i havent looked for that in particular but you can find just about anything on there and most major wrecking yards are on there and a lot of small ones too...check it out <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: some of us want a LSD for rear [Re: londart] #963210 09/14/09 12:45 PM
homerdog Offline
I've got the stock one on mine but I'm keeping it for now. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: some of us want a LSD for rear [Re: homerdog] #963211 09/16/09 12:07 AM
Everet Offline
REMEMBER: If your buying one from a salvage yard, there are 26 and 28 spline units. Correct me if I am wrong, I believe 95-97 have 26 spline axles in the rear, and 98-02 has 28 spline axles.
Ring gears are different size from front to back so you can't swap.
Good Luck
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: some of us want a LSD for rear [Re: londart] #963212 09/18/09 02:02 AM
Hydra747 Offline
Thanks a bunch for this and the prices are SUPER Cheap.............But decipher the codes if u can????????????????????(i mean the letters that THEY put under description----Which prolly really mean nothing)!
Will call during business hours to see......
web page
Re: some of us want a LSD for rear [Re: bombardj1] #963213 09/18/09 05:02 AM
DennisThompson Offline
Can't find a stock Kia LSD, Try RX7.
Re: some of us want a LSD for rear [Re: DennisThompson] #963214 09/18/09 06:29 AM
someone said a while back they only fit the front
Re: some of us want a LSD for rear [Re: bombardj1] #963215 09/18/09 06:54 AM
londart Offline
im not sure which codes your refering to
Lonnie
Re: some of us want a LSD for rear [Re: londart] #963216 09/18/09 12:28 PM
Dryver Offline
Have fun with that website. I was looking through it for a LSD rear end a couple months back near the Akron, Ohio area. Most of the ones that are listed as locker also say "ck" or "check locker" or something similar. I didn't find a single one that was actually a locker. I even drove a couple hours to look at one because I was told it was, but it turned out not to be.
If you find one you think might be LSD, ask the yard to either run the VIN by Kia to have them verify it or ask for the VIN and call Kia yourself.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
PHP: 7.4.33 Page Time: 3.283s Queries: 16 (0.005s) Memory: 0.6427 MB (Peak: 0.7668 MB) Data Comp: Off Server Time: 2026-05-30 02:16:45 UTC
