some of us want a LSD for rear
#963207
09/14/09 02:00 AM
some of have 2wd and some 4wd, but have none lsd carriers and are tired of sliding on the road because of only 1 rear wheel grabbing the road and on have a source for LSD's in there area's like pice-a-parts etc. that they are willing to check out. we have tried in our areas and they are not to be had.
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
Re: some of us want a LSD for rear
[Re: bombardj1]
#963208
09/14/09 02:12 AM
I as well would like to know the current sources for obtainment of rear axle LSD. I have searched for quite a while and came up with zero!
Stock for sure. Any one know?
If so then please let All of Us Know!
Thanks, Mikey
[Re: Hydra747]
#963209
09/14/09 02:24 AM
you might try the national locator for junkyards the website is car-part.com ..... i havent looked for that in particular but you can find just about anything on there and most major wrecking yards are on there and a lot of small ones too...check it out <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie Auto Parts Professional 95 sportage sold but not forgotten
[Re: londart]
#963210
09/14/09 12:45 PM
I've got the stock one on mine but I'm keeping it for now. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress. 2011 Kia Forte EX
[Re: homerdog]
#963211
09/16/09 12:07 AM
REMEMBER: If your buying one from a salvage yard, there are 26 and 28 spline units. Correct me if I am wrong, I believe 95-97 have 26 spline axles in the rear, and 98-02 has 28 spline axles. Ring gears are different size from front to back so you can't swap. Good Luck Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: londart]
#963212
09/18/09 02:02 AM
you might try the national locator for junkyards the website is car-part.com ..... i havent looked for that in particular but you can find just about anything on there and most major wrecking yards are on there and a lot of small ones too...check it out <img src="/forums/images/graemlins/cheers.gif" alt="" /> Thanks a bunch for this and the prices are SUPER Cheap.............But decipher the codes if u can????????????????????(i mean the letters that THEY put under description----Which prolly really mean nothing)! Will call during business hours to see...... web page
[Re: bombardj1]
#963213
09/18/09 05:02 AM
Can't find a stock Kia LSD, Try RX7.
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: DennisThompson]
#963214
09/18/09 06:29 AM
someone said a while back they only fit the front
[Re: bombardj1]
#963215
09/18/09 06:54 AM
im not sure which codes your refering to
[Re: londart]
#963216
09/18/09 12:28 PM
Have fun with that website. I was looking through it for a LSD rear end a couple months back near the Akron, Ohio area. Most of the ones that are listed as locker also say "ck" or "check locker" or something similar. I didn't find a single one that was actually a locker. I even drove a couple hours to look at one because I was told it was, but it turned out not to be.
If you find one you think might be LSD, ask the yard to either run the VIN by Kia to have them verify it or ask for the VIN and call Kia yourself.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
