Rating: 5
Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: Not just another 3.4 swap... [Re: IceBlueT] #964886 05/17/10 04:22 PM
G
Greg_Canada Offline OP
It's dyno'd about 10-15hp more than the stock sensor.
It plugs right in, however you need means to "tune" it (such as a FTC or MAPECU....
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964887 05/17/10 05:10 PM
IceBlueT Offline
ok, so not exactly a cheap endevor and not really worth it unless in your situation...thanks! <img src="/forums/images/graemlins/notooth.gif" alt="" />
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Not just another 3.4 swap... [Re: IceBlueT] #964888 05/17/10 05:41 PM
G
Precisely. Most of this stuff works together in tandem. 1 part may gain you 10 or 20 hp but all together (say a group of parts) probably 50 or more (just throwing numbers out there).
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964889 05/17/10 05:51 PM
IceBlueT Offline
ok cool. Really interested in hearing your dyno numbers once you get it all together. dyno'd mine last year just for sh$#'s n <img src="/forums/images/graemlins/notooth.gif" alt="" />. at 5,100 ft in fort collins, co, i put 166 hp and 195 ft. lbs. down. that's with a K&n intake, Poweraid Throttle body spacer, and a magnaflow race muffler welded into the stock pipe. since have added a dodge viper electric fan, so not sure if those numbers have changed or not.
Re: Not just another 3.4 swap... [Re: IceBlueT] #964890 05/19/10 04:01 PM
G
Those are some pretty good numbers... decent gain over stock...
As for me, dyno? maybe by july / august after the motor is fully broken in...
For reference, here is the baby the motor is going in:
Still deciding whether to put a hoodscoop in or not... i'm thinking 05 + taco hoodscoop... ideas?
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964891 05/20/10 03:37 PM
CJM Offline
I have a new "bolt on" universal
I can get you a pic of it on your year if your interested ..
83 Trekker SR5
NEW Trekker forum
Re: Not just another 3.4 swap... [Re: CJM] #964892 06/04/10 05:06 AM
G
Hrm the scoop looks alittle *too* massive for me... the fenders look awesome tho, sent the pics to my buddy with a 90', he's drooling.
Got some more work done on the motor (finally) after running to and from the stealer for parts...
Oil pump on, plug for dipstick installed:
Oil pickup and baffle attached
Rear main seal/ etc. installed
Oil cooler with new seals
That's all for now... hope to get back to it saturday... <img src="/forums/images/graemlins/ignore.gif" alt="" />
Cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964893 06/04/10 07:11 AM
kewlynx Offline
Looking good there Greg.
Am trying to remember; you need to use the 3.4 engine mounts for the swap, correct? IIRC there isn't a need to move anything on the frame otherwise.
Thanks!
**ubi apis- ibi salus**
Re: Not just another 3.4 swap... [Re: kewlynx] #964894 06/06/10 01:50 AM
G
Uses a 3.0 rad, tranny, motor mounts, oil pan, TO bearing.
Anyways, got alittle more done before i found out my torque wrench only goes down to 30lb-ft... argh....
Water pump, thermostat, knock sensors, water bypass:
Close up of the colt cams regrinds (much better than what i sent them)
Inside of heads
With valve cover installed (just for looks)
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964895 06/06/10 04:28 AM
CJM Offline
the one jornal in the pic looks a little rough ?
but , lookin'good Greg ...
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6528 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-10 01:40:07 UTC
