Rating: 5
Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Not just another 3.4 swap... [Re: kewlynx] #964906 07/22/10 06:40 AM
CJM Offline
lookin' good brutha!
83 Trekker SR5
NEW Trekker forum
Re: Not just another 3.4 swap... [Re: CJM] #964907 08/09/10 03:51 AM
Oyaji_Jon Offline
Status? I know you've got something going on up there... <img src="/forums/images/graemlins/kewl.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Not just another 3.4 swap... [Re: Oyaji_Jon] #964908 08/16/10 04:42 AM
G
Greg_Canada Offline OP
Hahah yeah you got me... just getting back from BC (vancouver and victoria) and getting settled back in...
View from my hotel room (view is north vancouver)
Got my car buffed/waxed/detailed while i was away
Got my dads 4runner's bush bar blasted and powdercoated
Blasted some parts
Some paint
Blasting the frame (UGH)
Ugh, gotta fix that before i put the motor in....
Prep for paint
[img]http://i148.photobucket.com/albums/s35/Greg_Canada/5vz%20supercharged%20swap/Truckprep011.jpg[/img]
Not nearly as fancy looking as Corey's, but it cleans it up alot
[img]http://i148.photobucket.com/albums/s35/Greg_Canada/5vz%20supercharged%20swap/Truckprep024.jpg[/img]
[img]http://i148.photobucket.com/albums/s35/Greg_Canada/5vz%20supercharged%20swap/Truckprep025.jpg[/img]
Atleast i'm seeing progress! LOL.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964909 08/16/10 07:02 AM
Oyaji_Jon Offline
Nice! You're definitely doing it up right. I don't think any of our junk is as fancy as Corey's... <img src="/forums/images/graemlins/lol.gif" alt="" />
Keep up the good work!
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964910 08/19/10 12:10 AM
chpfx Offline
Look'n great Greg keep up the good work. By the way got your last reply thanks for the tips and info. Just replaced the factory clutch now putting away funds for a new cam and sending head in for upgrades. Any suggestions for cams, looked on eng.bldr but haven't decided which one to get as of yet.
Re: Not just another 3.4 swap... [Re: chpfx] #964911 08/19/10 02:03 AM
CJM Offline
Nice Greg .. and wow .. I can only chuckle at the referance to mine .
seriously , your doing awesome work .. keep it up , you'll be having the nicest 4Runner ever !!
83 Trekker SR5
NEW Trekker forum
Re: Not just another 3.4 swap... [Re: CJM] #964912 08/21/10 01:12 AM
mosk Offline
That motor looks gorgeous, Greg -- great work!
BTW, when you have a minute, I replied to your PM on customtacos regarding the gauge pillar question. (Short answer: send me a photo so I can better see the issue. Thanks!)
Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Not just another 3.4 swap... [Re: mosk] #964913 09/10/10 03:55 AM
G
Got some more work done on the motor, custom fitted a fitting for a fuel pressure gauge:
Drilled the stock banjo bolt, threaded it with 1/8 NPT tap, and go M-F 90 deg elbow.
Threw the harness on to test fit where i can locate the sensor so it still hides under the timing cover.
Close up of the sensor installed:
Here you can see the 3.4 with 3.0 motor mounts and new rubber isolators, as well as the 3.0 "stiffening" plates.
I bought the correct tap from snap-on.ca (M10x1.25) ($7 and super fast shipping) and re tapped all the holes on the block. Tapped the stiffener holes and.... nothing, rusted right out. Thankfully i had a helicoil kit from a previous job for the correct size, and it worked perfectly (drill, tap, install coil, done).
It's getting there.... have lots of work to do under the truck (rust fixing)... yay...
Jeff i'll get some pics this weekend...
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964914 09/10/10 06:30 AM
Oyaji_Jon Offline
Very nice, Greg! Keep the updates coming...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Not just another 3.4 swap... [Re: Oyaji_Jon] #964915 09/25/10 03:39 AM
G
Got quite a bit more work done:
Got the harness together:
What a biotch to get the wires through the little grommet
Got the fuel line
Welded some plates in the frame
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6556 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-06-10 01:40:18 UTC
