Rating: 5
Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Not just another 3.4 swap... [Re: kewlynx] #964926 11/01/10 05:10 AM
G
Greg_Canada Offline OP
Lookin' good Greg!!
I use dielectric gel on plastic/rubber that needs a little help. Put a very light coat on your radiator hoses when you reach that point, and they'll work right on for you.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Wow... that saved my <img src="/forums/images/graemlins/butwiggle.gif" alt="" />... best tip so far! LOL... <img src="/forums/images/graemlins/lol.gif" alt="" />
This post will be dedicated to how much i hate downey and am glad they are no longer in business. Judging by the quality of my headers... i don't know how anyone was not pissed with buying from them.
OK here are the headers, with V-band clamps welded on and re-ceramic coated (i'll get to that)
The flanges... after i drilled them out to accept the stock OEM metal gasket, and got them milled flat because the flange was so warped...
The collecter pipe after i spent 3 hours hogging them out... because the welds were taking away 10% of the diameter of the tube... wow great work downey... also it's XMC coated for less friction / even better heat retention (ceramic + xmc drop the outside temp by 50%.... critical when running so close to the starter and clutch and fuel and brake lines...)
In the middle of blowing out the little pellets from the ceramic coating... oh guess what, there is a clear HOLE in the header... they missed a spot of welding the collecter! WTF downey!?!?! (and i missed it before re-coating)... my neighbour down the street has a monster arc welder (works for the city) and zapped it closed for me... but now it can rust there... stupid downey... not getting it recoated for that but still... wtf...
Headers installed, showing the EGT probe i got welded in... and the EGR flange, which was nicely NOT coated from downey, and was bare rusty metal... again WTF downey? what's wrong with you guys? (i got it coated)
Also, the middle / bottom bolt on the driver side header... took 20 minutes... all the other 11 bolts took 15 minutes to tighten... geez.... good work again downey!!! Btw... those flex head gear wrenches saved my <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> again on this one... soooo much easier than a standard wrench...
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964927 11/01/10 05:20 AM
G
Got all the engine bay wiring harnesses done...
Ran a 4ga. from the fusebox to a 60A fuse to the battery
Used the stock 4ga. re-loomed from starter to battery
Used stock alt wire (added loom)
Also hooked up 4ga from alt to 150A fuse to battery ("big 3" upgrade)
0 gauge for stereo (not hooked up yet)
Ran a 4ga. ground to the body and another to the engine.
Not the cleanest.. but it works and there is lots of space still...
Used the stock brackets for the evap but turned them / spun them until they fit... took a few days to figure it out LOL.. didn't have time to paint yet... trying to get it all running...
Another view showing the EVAP hoses as per ORS / TRD specs
And the view so far
So the rad i bought 3 years ago... was too tall.. had to redrill the brackets... and look at the rad cap, it doesnt stop at the right angle... RRRR.... will probably upgrade to an aluminum PWR rad next year... we'll see... stupid ebay...
Also, the lower rad hose would not fit with my 3" BL, went to napa and found one and cut it to fit... #8971 i believe...
Also, the heater control valve was hitting the bypass valve, had to spin it and redrill it.
Basically, i've had to modify everything to get it all to fit, but it hasn't been too bad... just taking my time. Got all the hoses ran, just need to hook up fuel, power steering return, the aftermarket gauges... for initial start up. Then drive to the shop to get the exhaust made and a battery tray made... smile Should be running this week if all goes well! <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964928 11/04/10 05:27 AM
G
Got it started today... damn it's loud... open headers.. it was after 11... pissed off a neighbour (oops <img src="/forums/images/graemlins/cyclops.gif" alt="" />)
Anyways, here's a vid after i fixed a few fuel leaks
And a pic of my "cockpit" LOL... so many gauges... having probs with the boost gauge, it just maxes out... calling speedhut tomorrow...
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964929 11/04/10 06:07 AM
Oyaji_Jon Offline
Wow, Greg! I bet the ear-to-ear smile that you couldn't wipe off your face didn't help your case with the neighbor, eh? <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Not just another 3.4 swap... [Re: Oyaji_Jon] #964930 11/04/10 09:26 PM
mosk Offline
Good going, Greg! Looks gorgeous! Glad you have it running now.
Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Not just another 3.4 swap... [Re: mosk] #964931 11/05/10 01:09 AM
CJM Offline
it runs .. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I know just how you feel <img src="/forums/images/graemlins/notooth.gif" alt="" />
great work bud !
83 Trekker SR5
NEW Trekker forum
Re: Not just another 3.4 swap... [Re: CJM] #964932 11/11/10 04:08 AM
matts Offline
Can't wait for a report on the performance on the road. -- Matt <img src="/forums/images/graemlins/kewl.gif" alt="" /> x2
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Not just another 3.4 swap... [Re: matts] #964933 01/04/11 10:52 PM
toyomorph Offline
just curious Greg hows the 3.4 working out?
canyon country explorer
1993 4x PUP
Re: Not just another 3.4 swap... [Re: toyomorph] #964934 01/05/11 12:30 AM
G
Got the exhaust on and drove it 700km... then took it off the road for the winter...
Drove good.. haven't brought it over 1/3 throttle tho... cant wait for the spring...
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964935 01/05/11 04:03 AM
kewlynx Offline
Taking one's time is sooooo worth it. Lookin' good Greg! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I like my little flex gearheads as well as my flexhead Snapon breaker-rachet too; great tools. <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6587 MB (Peak: 0.7694 MB) Data Comp: Off Server Time: 2026-05-29 15:18:25 UTC
