Page 3 of 8 1 2 3 4 5 6 7 8
Re: New here, swaping to a Daimler diesel. [Re: 300D50] #964973 10/18/10 11:06 PM
Kind of the reason I had asked was to bring you to discover these have an asymmetric pattern. I look at two errors that are easy to make, one as I did thinking it was symmetrical and drilling the most important hole wrong or making a reversed adapter.
I know now that you won't F'up your plate.
Re: New here, swaping to a Daimler diesel. [Re: OldColt] #964974 10/18/10 11:40 PM
3
300D50 Offline OP
I kinda figured that was the reason, and I thank you for bringing it up. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I honestly never noticed it until I looked for it, but it explains why my preliminary caliper measurements using the dowels weren't worth a toad fart...
I'm milling the first one out of particle board anyways, cheaper than aluminum or steel, and should be good for a sanity check/fastener check. <img src="/forums/images/graemlins/wink.gif" alt="" />
One nice thing is that the V5MT1 clutch housing and the Benz's intermediate plate both come off, so I can physically place one on top of the other for a sanity check.
Search has yet to bring up what you swapped that had a 6g72 pattern... I'm going to the 6g72 forum next...
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: New here, swaping to a Daimler diesel. [Re: 300D50] #964975 10/18/10 11:57 PM
I first setup a Starion gearbox behind a 6G72,
I did not like the compromised starter mounting so I changed to a late Mazda RX7,
This is shown with a B2600 tail housing but that has been changed to a modified RX7 housing that moves the shifter way forwards.
Here is the plate,
This plate was hand measured"My last" I used an aluminum tube that clamped in the main bearings and passed through into the gearbox to line them up. The old way of doing these.
Re: New here, swaping to a Daimler diesel. [Re: OldColt] #964976 10/19/10 12:33 AM
3
300D50 Offline OP
Nice! Always fun to see things that should never work together working together smile
The aluminum tube in the main bearings is a new one to me, guess if you've got it torn down for a rebuild anyways it makes sense to do it that way.
Not sure how my dad made the original plate, but I know he used the intermediate plate from the Benz and the starter plate from the KM145 to get the paterns.
I was still stuck in that overpriced taxpayer funded mandatory daycare called highschool when he made it.
How's the twin disk clutch setup working, I take it the engine picks up rpm quicker with the reduction in rotating mass?
Re: New here, swaping to a Daimler diesel. [Re: 300D50] #964977 10/19/10 12:58 AM
Most all of my conversions have been done with a mandrel through the bearings. Been doing it this way since the 70s. Many of the swaps involved taking apart engines and gearboxes that did not need to come apart. Real PIA. But labor used to be cheap.
It was only a year ago that I realized I could use my milling machine to measure with. Wish I had a fancier way but my accuracy has improved a bunch.
The small multiplate clutches hold allot of power and the engine is real snappy. They work real nice in the cars I build.
Re: New here, swaping to a Daimler diesel. [Re: OldColt] #964978 10/19/10 01:03 AM
Mad_Scientist Offline
never seen multiple clutches like that. Very cool <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: New here, swaping to a Daimler diesel. [Re: Mad_Scientist] #964979 10/19/10 01:14 AM
That clutch is a 140mm or 5¢" triple plate Quarter Master brand. This one has enough holding power for a generous turbo setup but will only have to live behind 280Hp or so in a 2200# car. Pretty easy life depending on the driver working the pedals.
Re: New here, swaping to a Daimler diesel. [Re: 300D50] #964980 10/21/10 11:37 PM
3
300D50 Offline OP
Took 4 days to get this far because of interruptions, but took a month to perfect the design. smile
It's not completely finished yet, I still have to turn snap-ring grooves in the inner bore to hold the pilot bearing in place, but that has to wait till I can bolt the flywheel on and do a sanity check on the dimensions.
There's some visible chatter marks on the one face because of some resonance of the boring bar, but other than that it's well within tolerance, and everything should be good.
It's such an amazing feeling to hold something that 4 days earlier was just a cad drawing, and a few weeks earlier was just a vision in my minds eye.
Now to test it on the 616 and wait for my flywheel bolts to come in....
Re: New here, swaping to a Daimler diesel. [Re: 300D50] #964981 10/22/10 03:16 AM
hazy_daze Offline
Psssh. All that new-fangled stuff.... Woulda been easier with a chisel and file!!!
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I'm glad this is the WWW, cause I couldn't have said that with a straight face. Seriously nice stuff, sir <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: New here, swaping to a Daimler diesel. [Re: hazy_daze] #964982 10/23/10 05:29 AM
3
300D50 Offline OP
I tried a file and chisel at first, but found that it was too boring for my attention spa OOHH! LOOK! SQUIRREL!. <img src="/forums/images/graemlins/drunk.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6563 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-11-02 21:49:56 UTC
