Re: 92 montero intermittent knock now with pictures [Re: K_Raider] #965399 10/01/09 05:45 AM
teal9550 Offline OP
looks like the oil pump is on the front of the motor so if i get it when i change the balancer I will rebuild the pump and hope that takes care of the knock and oil pressure light
Re: 92 montero intermittent knock now with pictures [Re: teal9550] #965400 10/01/09 05:55 AM
K_Raider Offline
Sounds good. Definately let others chime in before you take my word for it. But FWIW, I would try.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: 92 montero intermittent knock now with pictures [Re: K_Raider] #965401 10/01/09 05:06 PM
MBrannon Offline
I'd consider throwing in a new set of rod bearings as well.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: 92 montero intermittent knock(with Pixs now) [Re: teal9550] #965402 10/01/09 06:56 PM
Kevin C Offline
One way to know without pulling the motor apart is to send a sample of the oil out to a lab like Blackstone.
A quicker , cheaper method is to pull the filter off and cut it apart and look for chunks of bearing insert. If you see pieces, the entire motor will need to be gone through.
If the filter looks clean the lab would be a good second test.
Kevin
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6099 MB (Peak: 0.6654 MB) Data Comp: Off Server Time: 2026-06-07 11:32:51 UTC
