Page 3 of 5 1 2 3 4 5
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965423 10/03/09 02:50 AM
Oyaji_Jon Offline
...the Asians he sold me...
Ummmm, I don't think you can do that any more. <img src="/forums/images/graemlins/smile.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: Oyaji_Jon] #965424 10/03/09 01:26 PM
plh Offline OP
oops! fixed <img src="/forums/images/graemlins/lol.gif" alt="" />
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965425 10/03/09 02:30 PM
0778drz110 Offline
thanks for the right up! I should be picking my 8" IFS up in a few hours <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: 0778drz110] #965426 10/04/09 12:16 AM
0778drz110 Offline
6 and a half hours later with my uncle not knowing a clue what to do we pulled it!
4.625, 107k miles, $110! giggity giggity <img src="/forums/images/graemlins/smile.gif" alt="" />
Now to buy lockout hubs, 1" BJ spacer, Gen2 arms, Gen2 brakes, and Aussie locker all to go in at once and not pull it apart 5 times <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: 0778drz110] #965427 10/04/09 01:52 AM
plh Offline OP
Looks nice, I hope you grabbed the driveshaft.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965428 10/04/09 03:23 AM
0778drz110 Offline
damn...
<img src="/forums/images/graemlins/lol.gif" alt="" /> they're different I assume? Well, gives me an excuse to go tomorrow! I forgot some other stuff aswell... In FL they don't have as many junk cars(no rust) so I grabed it before some messican did...and I only guessed what I should need <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965429 10/04/09 03:47 AM
plh Offline OP
It was an early afternoon of rework, for sure not my favorite thing to do. 2 things required redo.
1. I was unpacking my parts container getting ready to get going today and noticed I had 4 brass thrust washers - crap! I forgot to install it on the already together Left side. Dropped it all apart again to reassemble.
Don't forget this:
It goes here:
2. The FSM seams a bit vague on how to assemble the Aisin hubs. First try I didn't have it correct. The FSM doesn't show that the Tension Spring needs to be wound into the Free Wheeling Hub Clutch. So I was perma locked
Finally have the whole Left side together, all the bolts properly torqued and new cotter-pins installed.
On to the driveshaft - working my way across the vehicle. I didn't see this documented anywhere. The 2.6l driveshaft is about 1" too long. It didn't bolt up - just too long. Measuring up the V6 dif quickly from the pinion flange to the cover it is almost 1" longer than the 2.6l dif.
This is the 2.6l shaft measuring 26 1/4" U Joint center to center:
This is the V6 shaft measuring 25 1/4" U Joint center to center:
Glad I still had the V6 shaft. Please note that pulling the driveshaft from the transfercase is a quick way to evacuate the lube. I have Redline all over my driveway now <img src="/forums/images/graemlins/frown.gif" alt="" />
The Left side is all together now too, but waiting for daylight to torque it up. Hopefully it is dry here on Sunday.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965430 10/04/09 03:50 AM
plh Offline OP
What do I fill the new dif with? I have several quarts of Mobile 1 75W 90. Is this OK?
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: plh] #965431 10/04/09 02:41 PM
MartySoCal Offline
Good write-up! <img src="/forums/images/graemlins/kewl.gif" alt="" />
75-90 synthetic should work very well in the diff.
So the V6 front driveshaft fits the 4 cyl. t-case with no mods? Did that V6 25-1/4" shaft come from the same manual trans V6 Raider as the diff? Is the 4 cyl a stick or auto? Would an auto trans V6 front driveshaft be longer? Would the early 3 speed 904 auto trans 4 cylinder shaft be shorter than the stick one?
Does anyone know if the Gen 2 reverse cut front diff assy. will fit the Gen 1 4 cyl. frame in a similar manner? Would the center axle disconnect be difficult to remove? 4.88's seem to be easier to find in Gen 2's and reverse cut is stronger in a front diff application. (I'm seeing alot of these in the yards from the clunker program <img src="/forums/images/graemlins/frown.gif" alt="" /> )
What about the Montero Sport front diff? Any advantage to that one? (Alot of these showing up, too)
Re: 2.6l Gen 1 Front Axle Swap with Gen 1 V6 LSD - How Too [Re: MartySoCal] #965432 10/04/09 03:13 PM
1
1986powerram50 Offline
Grasscat and Cheif (I think) have both swapped complete early SR suspesnion into there rigs. So Id say its doable
--keRby
Ad Inexplorta
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6513 MB (Peak: 0.7759 MB) Data Comp: Off Server Time: 2026-05-28 12:38:01 UTC
