Re: SOHC differential integrity? [Re: SKC] #965568 10/02/09 12:53 AM
DamKia Offline
Kia Moderator
I doubt the front diff would hold up under race conditions under continual shock loading of desert racing (airborne at times).
The diff is able to deal with the outright HP/torque in the S2000 OK, but the wheels never leave the road and there is minimal jarring to the driveline.
Coming from someone that has blown 2 fronts and a tcase (the other weak spot to consider), going no faster than 20 mph.
Re: SOHC differential integrity? [Re: DamKia] #965569 10/05/09 12:53 PM
DennisThompson Offline
I don't know how many of you know this but the Sportge dominated in off road racing for about 5 years in the stock short wheel base class. A mild lift, 31" tires, roll cage and a 2.3 strocker engine and off they went. They never talked about blown front diffs. I'm sure there was a little more to the build up than that but you don't use 4wd much when racing anyway. Low range 2wd is a blast in the sand,
Dennis
Re: SOHC differential integrity? [Re: DennisThompson] #965570 10/08/09 06:27 PM
sportagebandit Offline
i agree, if you are gonna be messing around in the desert you realy shouldnt need 4x4, although it would be nice for some situations.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5995 MB (Peak: 0.6526 MB) Data Comp: Off Server Time: 2026-06-21 09:53:11 UTC
