Drive shaft? #965623 09/30/09 01:30 AM
W
wytee Offline OP
Where can i find a replacement for my rear driveshaft? 88 toyota pickup 4x4. 6 inch lift.
"IM THERE BUDDY"
Re: Drive shaft? [Re: wytee] #965624 09/30/09 02:21 AM
4Crawler Offline
If you did not modify the shaft for the lift, most any pickup of the same wheel base and generation that you have would be a good donor.
Re: Drive shaft? [Re: 4Crawler] #965625 09/30/09 03:37 AM
W
wytee Offline OP
I tried an 86 but the bolts are bigger. I thought they were the same generation but am i wrong?
"IM THERE BUDDY"
Re: Drive shaft? [Re: wytee] #965626 09/30/09 04:00 AM
4Crawler Offline
Should all be 10m bolts, only the early 1st gen pickups had 8mm bolts on the drive shaft:
- http://www.4crawler.com/4x4/ForSale/DriveshaftSpacer.shtml#Introduction
Not hard to drill out the holes if needed.
Re: Drive shaft? [Re: 4Crawler] #965627 09/30/09 04:30 AM
Adam F Offline
Drill them or swap flanges.
97 4R, stock, daily driver
Re: Drive shaft? [Re: 4Crawler] #965628 09/30/09 06:04 AM
W
wytee Offline OP
ok. thank you.
"IM THERE BUDDY"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6097 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-16 13:06:29 UTC
