Page 2 of 8 1 2 3 4 5 6 7 8
Re: Balljoint spacers [Re: Oyaji_Jon] #965674 09/30/09 03:14 PM
V
vr4 Offline
as soon as i can afford it ill be picking up 3-4 sets
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Balljoint spacers [Re: Red1979] #965675 09/30/09 04:15 PM
powerRam50 Offline
they wont work for our trucks unless you get gen 2 upper control arms.are upper ball joints are press fit not bolt in like gen 2 montys.
Re: Balljoint spacers [Re: powerRam50] #965676 09/30/09 04:21 PM
jfarsang Offline OP
Good to know. Thanks powerRam50.
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: Balljoint spacers [Re: vr4] #965677 09/30/09 04:52 PM
Alex Kogan Offline
Get some spare tie rods with it too and maybe CV or two as well.
08 PowerWagon (stock!)
Re: Balljoint spacers [Re: Alex Kogan] #965678 09/30/09 06:21 PM
redbull Offline
Are you saying this because the spacers are hard on those parts?
Re: Balljoint spacers [Re: redbull] #965679 09/30/09 06:32 PM
Tag Offline
I doubt he is saying the spacers themselves are hard on those parts. I think what happens is since you do not bring the centerlink down you start to take the tie rods to the extent of there travel and potentially bend them. Same with the cvs but if these help with the camber it will take care of the cv joints somewhat as well. Now if you have manual locking hubs cvs should last some time any way. Gen 2 hubs are always locked but can have manuals put on to them I think.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Balljoint spacers [Re: Tag] #965680 09/30/09 06:55 PM
Alex Kogan Offline
Yes extra drop may go beyond capacity of tie rods ends. More drop increases force trying to bend those as well. They you negotiate obstacles. CVs pop out of front hub stripping snap ring sometimes, lets dirt in. Some CV actually grenaded when off roading being pushed beyond their working angle. 1" is actually is borderline limit what front end can handle. Smaller spacers < 3/4" seem to fair better. Even then you risk damage. If you plan to play around town and don't mind potential damage it's ok mod but if you like expedition style trave. I would stay with stock suspension. And please get bigger bolts to secure those at least M10 instead of stock M8.
Re: Balljoint spacers [Re: Alex Kogan] #965681 09/30/09 08:44 PM
0778drz110 Offline
It lets you lift more because the upper arm moves up farther away from the bump stops, thus you can crank the torsion bars more.
@ Alex Kogan- what lift would you say max is with the 1" spacer? 3" t-bar crank lift with the spacer? Or would that max out the CVs and tie rods too much?
Re: Balljoint spacers [Re: 0778drz110] #965682 09/30/09 10:50 PM
Alex Kogan Offline
It doesn't matter what "lift" you get. It's not a lift anyway in a true meaning of this tirm. It's increased down-travel what kills you.
Re: Balljoint spacers [Re: Alex Kogan] #965683 10/01/09 12:04 AM
Alex is right, We have done a lot of this down here in various ways. The solution is to add a taller bump stop to keep the travel within a safe area. Even without taller bumpstops i don't think too many people will have problems with breakage considering PA_JERO's Gen1 was running Gen 2 arms with a balljoint flip, maxed out t-bars and no bump stops which is more extreme than adding this spacer with a little lift. He did break tie rods but keep in mind this is serious rockcrawling with car sized rocks to crawl.
If you've seen PA_JERO wheel you'll wonder how he doesn't break more things some of our adventures
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.012s) Memory: 0.6506 MB (Peak: 0.7554 MB) Data Comp: Off Server Time: 2026-11-18 03:31:38 UTC
