Page 7 of 8 1 2 3 4 5 6 7 8
Re: Balljoint spacers [Re: 0778drz110] #965724 10/04/09 04:05 AM
Tag Offline
Couldn't you flip the tierods to the top of the knuckle? The Gen1 mounts under, couldn't you flip it on top? It give you a good 1/2"-1" raise in the tierod angle...
I have been wondering about this as well latley. How would you retaper the hole?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Balljoint spacers [Re: Tag] #965725 10/04/09 04:13 AM
0778drz110 Offline
oh I didn't know they were tapered...haven't taken that apart before...hmm
Re: Balljoint spacers [Re: 0778drz110] #965726 10/04/09 06:44 AM
motero Offline
Previously discussed.
http://www.4x4wire.com/forums/showflat.p...rue#Post1047052
Answer Bad Idea.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Balljoint spacers [Re: 0778drz110] #965727 10/04/09 04:06 PM
And it does NEED 37s! <img src="/forums/images/graemlins/evil.gif" alt="" /> Super swamper SX!
Toyo open country M/T's
Re: Balljoint spacers [Re: TOASTY] #965728 10/05/09 08:31 PM
3
300D50 Offline
Well, I'm confused once more.
The print says 25mm on high side, and 22.5mm on low side, but you say .9" high side, .8" low side.
25mm in inches is .98", and 22.5mm in inches is .88"
Which dimensions are correct?
Just trying to wrap my head around it all.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Balljoint spacers [Re: 300D50] #965729 10/05/09 09:29 PM
Grasscat Offline
Really,
Reread the post. He also said "So between 7/8 and 3/4"." He's speaking in general terms. The print speaks for itself.
Michael j
TreadLightly! Trainer
Re: Balljoint spacers [Re: Grasscat] #965730 10/06/09 06:30 AM
3
300D50 Offline
I did re-read the thread several times before posting.
jfarsang had said
Here is the original spacer being used in the UK:
when he posted the print,so I was unsure if he used those dimensions verbatim when he had the shop make em, or if he truncated them off to .9 and .8.
Hope I haven't pissed anyone off, I just want to be well-informed about a part that affects a vital system on my truck if I install it. smile
Re: Balljoint spacers [Re: 300D50] #965731 10/06/09 04:48 PM
jfarsang Offline OP
No problem as at all. Clarification is good. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I was generalizing using inches.
The image posted is the correct dimensions.
25mm high side / 22.5mm low side = 2.5mm taper spanning the diameter of the whole spacer.
Bolts are 10M x 1.25 x 45mm / fine thread pitch / Grade 10.9 (metric equivalent of Grade 8 SAE) with 10.9 grd washers.
There is a sheet with detailed instructions on how to install them, a disclaimer and note to have a wheel alignment done after the install.
I have 8 sets left. I'm starting to ship them over to the UK as our dollar is low and they are saving 1/2 off buying them from Australia.
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: Balljoint spacers [Re: jfarsang] #965732 10/08/09 10:26 PM
Alex Kogan Offline
Thanks for generous offer but I'll play it safe. I ripped my OldManEmu rear shocks in half in desert. That was unpleasant enough. Loosing front end could be disastrous or even catastrophic.
08 PowerWagon (stock!)
Re: Balljoint spacers [Re: Alex Kogan] #965733 10/09/09 12:33 AM
jfarsang Offline OP
No problem. That's what choices are for and it's good to have them.
Of course it would. That goes without saying. Shocks, tierods, balljoints, steering column, tires, rims, pitman arm, control arm bushings, etc... Any of these things can take out your front end.
Fortunately, if installed properly, these balljoint spacers do not affect the front end.
There are 13 monty's in the Vancover area running bj spacers up front and some with longer springs in the rear. Makes for a good combo.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6473 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-05-30 00:14:12 UTC
