Re: Rattling from transfer case? [Re: fokion] #966448 10/18/09 09:52 AM
2002_Sporty Offline
I found this link on the net that has to do with driveline noise. And I read a whole bunch of other forums that all came to this conclusion and/or exssesive blows to the T-case itself from previous owners abuse. Hope it helps.
http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: Rattling from transfer case? [Re: Everet] #966449 10/19/09 02:53 AM
Hydra747 Offline
I really don't understand how tire size would be an issue <img src="/forums/images/graemlins/confused.gif" alt="" />
I'd need to hear the logic behind it.
Me too. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Rattling from transfer case? [Re: Hydra747] #966450 10/19/09 04:16 PM
DamKia Offline
Kia Moderator
Stock tire and alloy rim = 43lb, 31" on steelies = 70lb.
More weight to spin up and more weight to slow down through the tcase. When you lose traction these forces are acting on the tcase. Exactly the same reason you wear out your brakes quicker with big tires (more than you would reasonable expect "numerically" correcting for odometer inaccuracies).
Re: Rattling from transfer case? [Re: fokion] #966451 10/20/09 02:04 AM
5
5jackz Offline OP
I managed to find one out of an automatic in the US - good thing I live close to the border. $ 225 USD out of a 2002 with 48000 miles. Border guy didn't charge any duty either. I've had the sporty since new and had 30's on their since almost day one. The 31's with alum rims ( weigh less then steel )have been on for 2 years. It's always had regular fluid changes since it was my wife's/family vehicle until recently, so I was kinda upset that it did what it did.Anyways new one is in and I went out hunting again- so far Ok
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: Rattling from transfer case? [Re: fokion] #966452 10/20/09 03:32 AM
jays2001 Offline
i have seen t-cases on ebay 150 to 300 reasonable and of corse alot higher.
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6118 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-06-10 06:27:28 UTC
