Re: Rear Gen II coil spacers ... Sequoia ?
[Re: off-roader]
#966547
10/06/09 06:43 PM
Ray I can take some pic. I'm take the 1994 sr on the trip, it has the Ironman setup on it. Sequoia spacers are on my 1992 RS.
[Re: tyty]
#966548
10/06/09 08:41 PM
OK, cool. BTW, which of the two (Iron Man or spacers) work better from your experience?
[Re: off-roader]
#966549
10/06/09 09:58 PM
Well the Iron Man kit is better ride but $500 Sequoia spacers bouncy but only $69 and faster to install
[Re: jfarsang]
#966550
10/07/09 01:51 AM
I ordered a set at $69.
I'll see how they fit when I get them. <img src="/forums/images/graemlins/kewl.gif" alt="" />
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on 89 Montero - Project 92 Pajero Exceed - Gone to a good home 92 Delica Chamonix - Gone to a good home
[Re: jfarsang]
#966551
01/05/10 06:57 AM
So did either of you actually install the Sequoia spacers on your gen II's yet?
What trimming (hopefully none) was required?
[Re: off-roader]
#966552
01/05/10 01:48 PM
I did. No trimming necessary. Just make sure you remove the rubber spring pad from the upper perch. They are a perfect fit. I've been running mine for a few months on the road, trail and towing. Zero issues <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Mad_Scientist]
#966553
01/05/10 03:08 PM
Good to know. It's one of my next upgrades. How much time did the install take & how hard was it to re-attach the track bar (is that what they call the bar behind the rear axle?) or was it even necessary to disconnect it?
TIA <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#966554
01/05/10 03:36 PM
TIA <img src="/forums/images/graemlins/kewl.gif" alt="" /> It didn't take long to do, may be a couple of hours. But I had already had all that stuff apart when I swapped my rear axle a couple of weeks beforehand. I call that bar the panhard bar, but I think some call it a track bar here. Disconnect it on the frame end. The trick is to put a jack under the rear axle and raise it just the right amount so there's no pull or push on the bar mounting bolt. The bolt needs to be torqued to 160ftlbs too when reinstalled. You will also need to disconnect the rear brake line and the lower rear shock mounts. Then you can lower the axle enough to get the springs out of the way. With the spacers in place and the springs on the lower perches, I slowly jacked the rear axle up until the springs pressed against the spacers to hold everything in place while I reassembling the rest. The only reason I didn't install them when I swapped my axle is because I knew I wouldn't have time to do that and crank the t-bars, and fiddle with the alignment. Have you trimmed your front upper bump stops yet? The next thing to tackle (for me too) is to decide whether to lower the panhard bar frame mount or make a longer bar so the axle rests in the middle again. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#966555
01/06/10 10:58 PM
One other thing, are renting spring compressors from the local Kragen Auto worth it to make this an easier job?
[Re: off-roader]
#966556
01/07/10 04:14 AM
One other thing, are renting spring compressors from the local Kragen Auto worth it to make this an easier job? Nah. Once you disconnect the brake line, shocks and panhard bar the axle can be lowered enough for the springs to fall out <img src="/forums/images/graemlins/shiner.gif" alt="" /> Spring compressors would be really awkward to use with the springs on the truck. I've only ever used compressors on coilover setups off the car. This job is a snap Ray. Is Michael helping out? <img src="/forums/images/graemlins/cheers.gif" alt="" />
