Re: Work gone FUBAR [Re: fasteddy] #966581 10/07/09 02:18 AM
kewlynx Offline
Camera time in the septic lines up here is $200/hr; what's yours? That, BTW, is the RESIDENTIAL rate. Not a lot of main line infrastructure here in the outlying areas.
Glad you're flush now. <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: Work gone FUBAR [Re: kewlynx] #966582 10/07/09 02:23 AM
We paid $200/hr for 8" sewer camera and leak testing, govt. inspected work in public r.o.w., in 1987.
The sewer business only has 3 rules.
1. The boss is an s.o.b.
2. Payday is Friday.
3. Sh*t doesn't run uphill.
Re: Work gone FUBAR [Re: fasteddy] #966583 10/07/09 02:29 AM
kewlynx Offline
RE: #3 Oh yes it can. A few years back my line was packed after years of disuse and zero maintenance. I dug down about 3 feet, sawzalled the pipe about where the pump guys said it was clogged. Rented a sewer jetter, and had at it for about 2 days on a 100' line and a slit trench to dump the mess. It was so packed in that 4" line that I had to use a trowel to work it into the bucket.
Glad I already had my HepB shots from EMS. <img src="/forums/images/graemlins/barf.gif" alt="" />
That sewer jetter saved me about $3K.
Re: Work gone FUBAR [Re: kewlynx] #966584 10/08/09 07:04 PM
sewerrat Offline OP
We charge by the foot, or straight time depending on the job. Around $1.50 a ft for basic water jetting and inspection. Added charges for root removal, cleaning beyond the basic, cleaning out treatment plant headworks, lift stations. Try to run 1200 to 1500ft per day. Have worked over 3000ft in a day. All of the video is saved to computer along with the inspection report. Most of our jobs are in the 8-10,000ft range.
With the Vactor combination cleaner, jetter + vacuume, we can suck up the debris. That's if we are provided a place to "dump the load". <img src="/forums/images/graemlins/lol.gif" alt="" /> Sometime we use baskets to remove small amounts. Still use buckets, but I have a fancy folding shovel. <img src="/forums/images/graemlins/smile.gif" alt="" /> Buckets are a last resort, confined space entry is gets old quick.
For the most part, the p00 crumbles up. Grease is a problem, esp. if roots are in the line. That can make a clog that's almost like reinforced concrete. Sometimes see piles of flakey stuff, egg shells and coffee grounds, that stuff dosen't break down, and corn. <img src="/forums/images/graemlins/barf.gif" alt="" /> Have a small collection of rings, marbles. Found a roll of quarters the other day, I don't want to know how they got down the toilet. <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
Keep using those garbage disposals, pour all that grease down the drain. Make sure you use low flow toilets and shower heads. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> My fellow sewer rats need the work. <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: Work gone FUBAR [Re: sewerrat] #966585 10/08/09 07:54 PM
52degrees Offline
If you ever find a Thomas the Tank Engine, my boys really aren't interested in it anymore.
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6174 MB (Peak: 0.7007 MB) Data Comp: Off Server Time: 2026-06-12 14:16:30 UTC
