Page 1 of 5 1 2 3 4 5
which gen1 A\T has the lockup converter? #966685 10/07/09 12:01 AM
zarktheshark Offline OP
I have searched many posts but could not find a clearly defined answer. I want to change out my 88 trans for one with a lock up converter and then mate that with a np231. I found a 89 tranny on CL but don't know if this will work. Can you guys tell from the pics?
http://seattle.craigslist.org/sno/pts/1398389605.html
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966686 10/07/09 12:19 AM
That's the wrong side of the converter to tell for sure. There's a code plate on the dside of the tranny - Check yours and see if it's a P code. The lockup should have an R in the same place. I think I have the letter codes right, but in any case, the new tranny should have a letter code later alphabeticly to be a lockup.
The change apparently was a running change in the 89 model year. Never seen an 88 with one, all 90's seem to have one, and afaik, most 89's had one.
It's worth getting. You'll have to swap your 4cyl bellhousing onto the new tranny to fit the 2.6. You'll use the 2.6 flexplate, IIRC. Get all those spacer thingys on his flexplate, though.
Re: which gen1 A\T has the lockup converter? [Re: fasteddy] #966687 10/07/09 12:24 AM
FrankR Offline
I thought it was a running change in '90 - and that no '89s had Lockup converters....... except for mine <img src="/forums/images/graemlins/smile.gif" alt="" /> - but mine came from a '91, IIRC.
Frank
Re: which gen1 A\T has the lockup converter? [Re: FrankR] #966688 10/07/09 12:39 AM
fasteddy, you say it's worth getting. do you mean if it is a lockup or even if its not? my trany is working fine currently.
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966689 10/07/09 02:09 AM
plh Offline
Please correct me if I am wrong, but the Mitsu tranny won't mate to a NP231
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: which gen1 A\T has the lockup converter? [Re: plh] #966690 10/07/09 02:28 AM
It will with a pice of pipe, two flat plates, and a spud shaft. And a lot of skull sweat.
I would not bother unless I got a lockup in the deal. It saves 300rpms at a 3000rpm cruise in tranny slip. It's worth saving 10%.
I have an 89 with the lockup. Looked like the original install when I took it out to fix the oil pump leak.
I'd install new front and rear and shifter shaft seals if I did nothing else to the donor tranny.
Re: which gen1 A\T has the lockup converter? [Re: fasteddy] #966691 10/07/09 05:29 AM
KevinC says the np231J, 23spline will mate up with our trany, but there are a few minor issues to figure out. I'm going to work on this hear and there, so i'll have plenty of time to figure it all out OR figure out if I just don't want to do it:) thx for help all.
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966692 10/07/09 06:50 AM
Kevin C Offline
I did?
Crap, I am really loosing it.
That looks like a V6 non lockup. STill should be an improvment over the 4 cyl converter. You will need to use the converter with the V6 tranny.
Kevin
Re: which gen1 A\T has the lockup converter? [Re: Kevin C] #966693 10/07/09 03:53 PM
my bad, it was nathanC smile
http://www.4x4wire.com/forums/showflat.p...&PHPSESSID=
question, in what way is the v6 tranny better than the i4?
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966694 10/07/09 04:14 PM
W
WagonMaster Offline
Because the bellhousing fits the FAR superior V6. Duh!
<img src="/forums/images/graemlins/lol.gif" alt="" />
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6476 MB (Peak: 0.7676 MB) Data Comp: Off Server Time: 2026-05-30 10:44:16 UTC
