Page 3 of 5 1 2 3 4 5
Re: which gen1 A\T has the lockup converter? [Re: fasteddy] #966705 11/15/09 04:45 PM
zarktheshark Offline OP
I'll get pics up today. on the red tag, I have the following info.
asian aw
model no.
03-72L
Serial No.
90C P 60912
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966706 11/15/09 05:50 PM
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966707 11/15/09 07:53 PM
Kevin C Offline
Sure looked like the lockup converter to me. The PN is the correct one as as well.
Kevin
Re: which gen1 A\T has the lockup converter? [Re: Kevin C] #966708 11/15/09 09:37 PM
ok, I'm glad this is the lockup one. hope to put this in the rig in december when i have some time off.
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966709 04/01/10 05:47 PM
monte Offline
I'm gonna bump this thread from the past... I've got 2 different trans that I picked up now...
1 is a KM148-6-FS1 and the other is a V4AW2-3..
The KM148-6 is out of a late 90 and I don't think has the lockup??? (no documentation supports this)..
The V4AW2-3 is from a 91 1st gen V6 and does have lockup...
But I'm hearing that the KM148's might have them?
AHHHHH!!!! Would like to get REDCAR converted before the Death Valley trip <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: which gen1 A\T has the lockup converter? [Re: monte] #966710 04/01/10 06:06 PM
I thought the KM148 only came behind the 4-cyls.
Re: which gen1 A\T has the lockup converter? [Re: MontyMcV] #966711 04/01/10 07:25 PM
monte Offline
not according to CAPS. 3000-RR COIL and WAGON models show the KM148-6-FS1
Re: which gen1 A\T has the lockup converter? [Re: monte] #966712 04/01/10 08:41 PM
both those models will be a 3.0. A 2.6 will be a swb, every time in this market. P code will be a non l/u, IIRC...
Re: which gen1 A\T has the lockup converter? [Re: fasteddy] #966713 04/01/10 11:24 PM
monte Offline
true.. but going back to my original question...
what's the difference between a KM148-6-FS1 and a V4AW2-3 ??
Both were shown as options on the 90/91 6G72.. but the KM148 shows a "non locking clutch"
Just don't want to get too far into this swap and find I'm screwed..
Re: which gen1 A\T has the lockup converter? [Re: monte] #966714 04/01/10 11:35 PM
justice Offline
If you have both trannys, why dont you just swap in the 91 unit? The one designated as KM148 most likely is non-lockup. I swapped out the KM148 that was in my 89 with a 91 lockup unit.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6503 MB (Peak: 0.7558 MB) Data Comp: Off Server Time: 2026-05-29 15:01:44 UTC
