need 5 speed trans #966864 10/07/09 11:36 PM
teal9550 Offline OP
finally got the montero running & thought I was ready to roll only to dicover the the trans wont shift into 4 gear. talk about frustrating. to recap I bought this truck and the trans was sitting in the back, the former owner said it needed a clutch so I bought it cheap (350)I put a clutch in it mounted the trans, put a weber on it did all the brakes changed all the fluids cleaned the crap out of it. So does anyone have a trans there not using Help help
Re: need 5 speed trans [Re: teal9550] #966865 10/08/09 01:10 AM
K_Raider Offline
I bought my Raider with first and third grinding when you let out on the clutch. The previous owner thought it was the clutch also so he put a new one in it. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I knew it wasn't the clutch first time I heard it. At least I got a new clutch for my Montero out of it. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Good luck. I'm sure someone on here has one or knows where one is.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: need 5 speed trans [Re: K_Raider] #966866 10/08/09 02:43 AM
Sit tight. I think someone here in AZ has one.
Re: need 5 speed trans [Re: JohnnyBfromPeoria] #966867 10/08/09 03:09 AM
W
WagonMaster Offline
I've got one. I pulled it from Bertha, the 17 year old 2-ton stripper, so I'm not sure of it's condition. I intended to use it as a core at the junkyard to get a good shape AW4 from an XJ (Cherokee and the like), but can find others instead.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: need 5 speed trans [Re: WagonMaster] #966868 10/08/09 03:39 AM
V
vr4 Offline
is bertha a 2.6 or a v6?
i think the OP needs one for a 2.6 based on the weber comment. though i do need a 5 speed and t-case for a 1G V6
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: need 5 speed trans [Re: vr4] #966869 10/08/09 05:22 PM
W
WagonMaster Offline
Bertha was a V6. I'm rebuilding the mill for use in my SWB, but the 5 and T are spares since I'm going to go with an AW4 and NP242.
Re: need 5 speed trans [Re: WagonMaster] #966870 10/10/09 05:08 AM
teal9550 Offline OP
Ok so I have decieded to rebulid the 5 speed does anyone have any tips can i seperate the trans and transfer case when removing and installing it from the truck? Its a total pain in the A-s to stab it those together. yes it is a 2.6l
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6150 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-21 21:47:49 UTC
