Re: 1st gen pickup Driveshaft rattle [Re: OldColt] #967323 10/20/09 11:21 PM
Mikewarme Offline OP
It must go through a cluster gear, otherwise how would you switch gears if it went straight through.
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967324 10/21/09 01:12 AM
No. The cluster gear input and output gears on the mainshaft are not locked to the mainshaft in hi range, just in low range. As well, the chain drive spsrocket is not locked to the mainshaft, so the chain is not driven. In hi range, the two parts of the mainshaft are locked together so the drive is direct to the rear driveshaft.
It is fairly simple to remove the tcase output housing and chain cover and check the rear mainshaft bearing for slop.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5956 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-11-18 11:55:25 UTC
