Re: 1st gen pickup Driveshaft rattle
[Re: OldColt]
#967323
10/20/09 11:21 PM
It must go through a cluster gear, otherwise how would you switch gears if it went straight through.
[Re: Mikewarme]
#967324
10/21/09 01:12 AM
No. The cluster gear input and output gears on the mainshaft are not locked to the mainshaft in hi range, just in low range. As well, the chain drive spsrocket is not locked to the mainshaft, so the chain is not driven. In hi range, the two parts of the mainshaft are locked together so the drive is direct to the rear driveshaft.
It is fairly simple to remove the tcase output housing and chain cover and check the rear mainshaft bearing for slop.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5942 MB (Peak: 0.6425 MB) Data Comp: Off Server Time: 2026-11-16 08:39:31 UTCValid HTML 5 and Valid CSS
