AC fan mod question #967343 10/11/09 06:29 PM
1
1986powerram50 Offline OP
Yo guys almost have my 95 SR figured out waiting on a Cam Position Sensor. Figured I might as well do something till then. So I busted out my chiltons and read the wiring diagram for the AC condensor fan relay and what not. How would be the best way to do the AC fan mod?
Theres a blue and white wire that has 12v 24/7 and the other one is black and blue and just a ground. Thats apperantly the one controlled by the relay.
I'd prefer for it to work when the AC comes on with out me making it also. If it wasnt for that Id just run 2 new wires to a switch and be done.
--keRby
Ad Inexplorta
Re: AC fan mod question [Re: 1986powerram50] #967344 10/12/09 04:29 AM
That's intersting. I was told that the circuit just needed to have switched 12v+ added to get the fan to run off a switch, while retaining the a/c/auto-on function. I will be following this one, as I want/need to add the ability to have the aux fan work off a switch when the a/c is off. That little fan really helps out! It's also an expensive bugger to replace if you can't find a junkyard one.
Re: AC fan mod question [Re: 1986powerram50] #967345 10/12/09 04:51 AM
Oyaji_Jon Offline
If the ground is switched, you could cut the ground wire you mention, solder in a wire going to a switch that is connected to ground and then heat shrink the soldered connection. Pretty easy to do, and you retain normal functionality of the fan while adding manual control.
HTH
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: AC fan mod question [Re: Oyaji_Jon] #967346 10/12/09 04:59 AM
Acknowledged. I didn't think it was ground switched, though, so this is news to me. Guess I'll have to haul out my voltage meter.
Re: AC fan mod question [Re: JohnnyBfromPeoria] #967347 10/12/09 06:07 AM
Oyaji_Jon Offline
John, I don't know what the case is. I was just going off of what he stated in his post. Hope I didn't add any confusion.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: AC fan mod question [Re: Oyaji_Jon] #967348 10/12/09 11:32 PM
1
The ground is switched. I work at an plumbing heating electrical shop, I'm off work and waiting for the electrician to get off work now. <img src="/forums/images/graemlins/lol.gif" alt="" />
--keRby
Ad Inexplorta
Re: AC fan mod question [Re: 1986powerram50] #967349 10/12/09 11:34 PM
1
BTW Ive also metered and read the Chiltons both say the ground is switched depending upon the relay
--keRby
Ad Inexplorta
Re: AC fan mod question [Re: 1986powerram50] #967350 10/13/09 12:58 AM
3
300D50 Offline
Add in another relay with the contacts in parallel with the existing one. then it's just a switch and you're set.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: AC fan mod question [Re: 300D50] #967351 10/13/09 02:45 AM
1
Walt, Ill call you for more info. The electrician I wanted to ask wasnt back yet and i needed to go home.
Maybe Ill make a nice write up on how to do this.
--keRby
Ad Inexplorta
Re: AC fan mod question [Re: 1986powerram50] #967352 10/13/09 03:21 AM
ncdieselwrench Offline
I've done this on my 91 but it uses switched 12v not ground.
This is a rough wiring diagram of what you can do if you want to use a relay and a switch.
85 Fused switched 12v or ground
86 Fused constant 12v or ground
30 A/C fan
87a Factory A/C fan wire
87 Ground
You can either used switched gound or switched 12v to activate the relay just keep in mind that if 85 is 12v than 86 has to be ground, and vice versa. Fuses are your friend don't be afraid to use them, the whole point of using a relay is so you don't draw a bunch of current through a switch, typically a relay is rated for 30 plus amps, when your $3 switch from the store can handle 15 or less amps. Also using a relay this way allows you to manually control the fan when you want to and also allow it to work automatically(factory).
1993 Chevy Suburban 2500- Tow Rig
1991 Mitsubishi Montero LS LWB
SR Parts:
Rear Axle
Coils
Trailing Arms
Front Calipers
and soon to have UCA's and idler arm.
Dual Bouncies
Air Lift Airbags
Aisins
33x12.50x15 Custom Grooved TSL's
Body lift in the near future.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6418 MB (Peak: 0.7652 MB) Data Comp: Off Server Time: 2026-11-04 21:57:36 UTC
