Automatic Overdrive #967815 10/14/09 09:00 PM
rodeorat Offline OP
What auto overdrive trans would work in a 1978 Dodge 150 4x4 with a 318? Not interested in the add on type such as gear venders.
GOD Said It, I Believe It, That Settles It.
Re: Automatic Overdrive [Re: rodeorat] #967816 10/15/09 06:23 AM
There are some Dodge OD autos that will go in. You'll be making a new cross member, or supplying a later piece. The steering column can be retained or swapped out if you want the shifter scale to read correctly, drivshafts, and other stuff. Swap the trans and t-case, or use the NP203 and 205 doubler. Get the large bearing/large bolt pattern D44 front axle.
Look for an late 80's W150 donor truck, or Ramcharger, and get everything you need.
PHP: 7.4.33 Page Time: 1.691s Queries: 15 (0.007s) Memory: 0.5872 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-11-15 10:08:31 UTC
