Is not priming your oil pump after install a problem
#969358
10/24/09 12:15 AM
I just finished installing my new oil pump and buttoned up everything when I realized that while everything was going so smoothly i forgot to prime the pump. IS this going to be a large issue, warranting me to remove it and prime it or will it be ok? Is there another way to prime the pump by pumping oil into somewhere in the block? Thanks Chris I also just want to apologize if anybody thinks this is a repeat, I searched for a previous thread and couldnÆt find it. <img src="/forums/images/graemlins/scared.gif" alt="" />
87 Dodge Raider 4.3 Vortec work in progress 89 Dodge Raider 3.0 V6 Fully Restored Links are in my Bio to Photos
Re: Is not priming your oil pump after install a problem
[Re: Renegade]
#969359
10/24/09 03:03 AM
I know on my 2.4 truck, I pulled the oil pump all out and disassebled it to do a silent shaft delete. All they said was to pack the gears full of grease.
Whats the worst that could happen? Its just a motor......
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#969360
10/24/09 03:20 AM
One thing to try is this: Fill the truck with oil, and loosen the oil filter a couple of turns. Using a blowgun on an airhose, and a rubber donut (or even your hand) to seal the oil fill hole, force air into the crankcase using the PCV hose or similar. Even if you can only get .5 in there, the pressure will force oil up the pickup, through the pump and out the filter mount.
Good luck!
88 Trooper, 2.6 5spd 89 Trooper RS 92 Montero
[Re: 4runnerpilot]
#969361
10/24/09 03:44 AM
You're really going to want to read this thread, titled "Bob's 3.0L Engine": http://www.4x4wire.com/forums/showthread...ge=4#Post916736They start talking about the oil pump around page 19 or so.
89 Raider V6 manual 89 Montero 2-door Coupe "Super Legera" 91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
[Re: MarcDurant]
#969362
10/24/09 04:52 AM
You can pour oil down the tube from the oil filter, that sometimes does the trick.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: Renegade]
#969363
10/24/09 05:00 AM
I did the same, forgot to try priming it. been 7k since no problems yet <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> but it did come in a bag dripping w/ oil and I covered the engine w/ assembly lube
[Re: mitsumonki]
#969364
10/24/09 04:22 PM
remove the oil sending unit and fill the cavity with oil with a oil squirt can
[Re: 4runnerpilot]
#969365
10/24/09 05:13 PM
Good luck! This works even better if you have somone crank the engine over while you do pressurize the crankcase. Regardless its always good to pull the plugs to crank the engine over when priming it. Its a lot less work on the starter, the rod bearings dont get loaded up and the motor spins over a lot faster, helping to get the pump primed. All this is worth it to avoid any chance of a dry start. Kevin
