99 sport into 93 max
#969561
10/26/09 06:34 PM
will a 99 sport 3.0 bolt to the 93 3.0 trans?
Re: 99 sport into 93 max
[Re: mitsumonki]
#969562
10/27/09 02:26 AM
Should let us know how it works out tho!!
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#969563
10/27/09 02:32 AM
All 3.0 3.5 and 3.8 blocks have the same bellhousing and motor mount mounting locations. So yes, from what I have seen it should bolt in. BUT the biggest problems you would have is the electronics matching up. might have to use the MM intake.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: mitsumonki]
#969564
10/27/09 02:43 AM
I thought about useing the 24 valve quite a few years back, untill I learned of all the stuff I'd have to do, esp. in CA to meet emmissions. Whole wiring harness and ECU and stuff like drilling/ welding 4 O2 sensor mounts for the 24valve setup. If I was gonna go to all that trouble I'd get the 3.5 or 3.8 SOHC.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#969565
10/27/09 04:53 AM
yeah 3.5 would be nice but i might get a good deal on a whole sport that was rolled
[Re: mitsumonki]
#969566
10/27/09 06:34 PM
That 99 Sport engine will bolt up to the bellhousing fine. The side mounts may be a bit different though and may need some mix& match to bolt up.
That swap will make a nice driving pickup.
[Re: OldColt]
#969567
10/28/09 02:04 AM
FYI: I was told by a fellow on outerlimits, that the 6g72 and 6g74 have slightly different mounts. That require some modification.
--keRby
Ad Inexplorta
#969568
10/29/09 11:25 PM
[Re: mitsumonki]
#969569
10/29/09 11:31 PM
so my plan is to have complete obd2 with the bigger sport gas tank and evaporate system. what else should i try and swap over? I was thinking power door locks would be nice <img src="/forums/images/graemlins/smile.gif" alt="" /> the front wishbones are toast but the brakes seem ok. are they bigger?
[Re: mitsumonki]
#969570
10/29/09 11:43 PM
I look forward to you doing a "how to" ... <img src="/forums/images/graemlins/kewl.gif" alt="" /> Maybe someday I'll do something like that , that is if I can move outta CA. I'm still getting by with my crank snout damaged 3.0 12 valve. When the leaks finally cause my T-belt to break or bearings to seize maybe I'll do a 3.5 SOHC. I find more wrecked 2wd M.S.s than other mitsus in the yards anyway. God luck <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6387 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-06-16 15:19:36 UTCValid HTML 5 and Valid CSS
