Upper control arm ?? #970010 10/31/09 04:19 AM
minydigger Offline OP
I recently added a 2" spacer to my sporty and noticed the upper control arms arms are kinda close to the coils now any way to change or add a BJ spacer?
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
Re: Upper control arm ?? [Re: minydigger] #970011 10/31/09 08:25 AM
6
69442 Offline
BJ spacer ??
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Upper control arm ?? [Re: 69442] #970012 10/31/09 01:43 PM
Ball joint spacer
Re: Upper control arm ?? [Re: minydigger] #970013 10/31/09 02:48 PM
2002_Sporty Offline
check out this site:
http://upyourkia.com/
Everet of this site makes these.
I myself along others at 4x4wire.com use this kit.
Includes:
3" Front Lift Spacers
3" Rear Lift Springs
3.125" Rear Bump Stops w/hardware
Front Sway Bar Drop Legs for Lifted Sportage
Hope this helps.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: Upper control arm ?? [Re: 2002_Sporty] #970014 10/31/09 08:10 PM
I have already built the spacers and got tj coils for the rear so the lift is complete and installed. Just was wondering if there was any ways to relieve the upper Ball joint some.
Re: Upper control arm ?? [Re: minydigger] #970015 11/01/09 01:30 AM
Everet Offline
Take some pictures and show us your dilemma.
Re: Upper control arm ?? [Re: Everet] #970016 11/02/09 02:57 AM
Hydra747 Offline
I searched and checked....all over creation on this forum.....
I know that someone else posted about Asia for Longer Forks for the Sporty...
Anybody???????????
Re: Upper control arm ?? [Re: Hydra747] #970017 11/02/09 07:03 AM
fokion Offline
longer forks will not relieve the stress from the upper c arm joint
you need a spacer there or fab a new control arm
Re: Upper control arm ?? [Re: fokion] #970018 11/02/09 08:48 PM
Hydra747 Offline
My idea was that if we find this company then maybe they have other modifications available for the IFS setup in our Sportages? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Upper control arm ?? [Re: minydigger] #970019 11/06/09 02:17 AM
DennisThompson Offline
If you was to add an upper BJ spacer and left the lower control arm alone the differant angles of the two control arms would through your allignment so far off you would never get it alligned and your bump steer would be bad. A better way to keep your upper arm from hitting is keep your sway bar attached or add a limit strap. I have 4 inches of lift and with over 100,000 miles, trips to Moab and a little sand and snow jumpping mine has never hit.
Dennis
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6351 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-04 23:58:20 UTC
