Page 2 of 4 1 2 3 4
Re: Rear leafs flat as a board. [Re: 0778drz110] #970446 11/11/09 04:46 AM
87monty Offline OP
I got ya. well yeah im kinda stuck re arcing or add a leaf.
I was wondering if the toyota springs were around the same and just switch them out.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Rear leafs flat as a board. [Re: 87monty] #970447 11/11/09 07:12 PM
0778drz110 Offline
If you could measure the raider leafs, I'll post the toyota leaf measurements
length eye-to-eye
length from t front eye to pin
length from rear eye to pin
Re: Rear leafs flat as a board. [Re: 0778drz110] #970448 11/11/09 07:28 PM
LandRaider Offline
Raider leafs are totally unique as far as I could tell. IF you want to put other springs in there, you're going to need to cut off your old mounts, and put on new ones in different locations.
Thats what I did to get the correct lift in the back of my raider.
Re: Rear leafs flat as a board. [Re: LandRaider] #970449 11/11/09 08:36 PM
CwnAnwyn Offline
I just went out and measured my 87 SWB rear leafs. They measured 3" wide, 48" long, front to back they were 21"s from front eye to center pin to 27"s to rear eye. This was measured on my parts truck so they may be a fraction off either way.
According to http://www.generalspringkc.com/index.php?p=catalog&parent=158&pg=1
79-83 Toyota p/u rear leafs are 2 3/8s wide, 47 1/4 long, 20 7/8 x 26 3/8. (x is center pin)
84-88 Toyota p/u leafs are 2 3/8s wide 47 1/4 long, 20-1/2 x 26-3/4.
73-91 Chevy Blazer springs (front 47") are 2.5" wide, 23 1/2 x 23 1/2.
76-92 Jeep wagoneer springs 2.5" wide, 47" long, 22 1/2 x 24 1/2.
I've been playing with longer flatter leafs for the back of my raider to get more droop/articulation. Once I have them completely ironed out I'll post up on them. <img src="/forums/images/graemlins/smile.gif" alt="" />
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI
84 K5, 350/700R4,36" TSLs, spooled fr/rr
74 VW Bug- volksrod project
68 VW Fastback, 2L T4 powered
Re: Rear leafs flat as a board. [Re: CwnAnwyn] #970450 11/11/09 08:51 PM
0778drz110 Offline
looks like 79-83 yota is your chance <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Rear leafs flat as a board. [Re: 0778drz110] #970451 11/12/09 01:40 AM
Why doesn't anyone do the leaf spring over the axle? Isnthat one of the way to lift a regular domestic truck? Don't hey use blocks and longer ubolts, etc...?
Re: Rear leafs flat as a board. [Re: Mudraider] #970452 11/12/09 01:57 AM
0778drz110 Offline
I said that, but they would probably bend like spring over samurais, yjs, etc. Most spring overs tend to bend the spring eventually (not to mention his has a turbo motor).
Re: Rear leafs flat as a board. [Re: 0778drz110] #970453 11/12/09 05:46 AM
CwnAnwyn Offline
I had considered spring over at one time, but you would end up with about 3+ inches of lift in the back from the diameter of the axle tube. Kind of hard to crank the T-bars enough to level that out up front. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Z
87 Raider TSI
Re: Rear leafs flat as a board. [Re: CwnAnwyn] #970454 11/13/09 01:14 AM
the turbo motor on leaf springs needs some help with spring wrap. A traction bar above the axle would be nice. Maybe off the diff chunk to a mount in line with the front spring eyes?
Re: Rear leafs flat as a board. [Re: fasteddy] #970455 11/14/09 12:35 AM
Why cant I find measurements for the rear leaf springs? I went to a local shop, the dude spent about 20 mins looking thru all his books for the Montero/Raider apps, but couldn't come up with the spring measurements. Anyone got any help with that?
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6448 MB (Peak: 0.7496 MB) Data Comp: Off Server Time: 2026-07-14 12:26:21 UTC
