Page 1 of 4 1 2 3 4
Rear leafs flat as a board. #970436 11/02/09 08:40 PM
87monty Offline OP
What is a good Combo? Im not looking for a quick fix really.
Is there any leaf-packs that are pretty much a bolt up but with a good ride still? I plan on towing a small trailer soon as well. <img src="/forums/images/graemlins/smile.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Rear leafs flat as a board. [Re: 87monty] #970437 11/02/09 08:42 PM
Find a truck spring shop and get the old ones re-arched and add a leaf. They retemper the steel, too, in most cases. Not very expensive at all...
Re: Rear leafs flat as a board. [Re: fasteddy] #970438 11/02/09 08:46 PM
87monty Offline OP
It works pretty good? I think there is a shop downtown that may do it. So no other leaf pack that may bolt up?
What add a leaf do you suggest?
96 SR
Re: Rear leafs flat as a board. [Re: 87monty] #970439 11/02/09 08:52 PM
Around here it's Big Moe Spring and Brake, a chain, I think. I'd take their recomendation on the add on, if any. I'd also get the teflon interleaf thingys for smoother ride, and new bushings. Adding a leaf will make the pack a lot stiffer, which it may not need, and somewhat limit articulation...
Re: Rear leafs flat as a board. [Re: fasteddy] #970440 11/02/09 09:29 PM
87monty Offline OP
Where would I find the bushing kit is there a part number or good aftermarket brand?
96 SR
Re: Rear leafs flat as a board. *DELETED* [Re: 87monty] #970441 11/06/09 03:37 AM
Post deleted by fasteddy
Re: Rear leafs flat as a board. [Re: fasteddy] #970442 11/06/09 03:39 AM
0778drz110 Offline
you could try spring over? If you figure 4-5" from SPOA and about 2" from sag you get about 3" lift...
Re: Rear leafs flat as a board. [Re: 87monty] #970443 11/06/09 04:32 AM
Ask the shop who does them. It's what I would do. Always ask the pros...
Re: Rear leafs flat as a board. [Re: 0778drz110] #970444 11/07/09 09:41 PM
87monty Offline OP
Spring over? Sorry not sure what that is. I now have about 1.5 inches of down travel befor it hits the stops. Kind of annoying on the trails, and speed bumps for that matter!
I still have not called areound to see who does the work kevin was talking about been pretty busy this week.
96 SR
Re: Rear leafs flat as a board. [Re: 87monty] #970445 11/08/09 02:27 AM
0778drz110 Offline
leaf spring over the axle, stock springs are under the axle like a jeep YJ or samurai. Might not be a good idea since you're going turbo with 33s....
1.5" uptravel right? not downtravel? You could do an add-a-leaf with maybe a re-arch with the toyota lift shackles to get some articulation <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.450s Queries: 16 (0.008s) Memory: 0.6448 MB (Peak: 0.7478 MB) Data Comp: Off Server Time: 2026-07-14 21:34:42 UTC
