Page 1 of 6 1 2 3 4 5 6
Strengthening KM145 5 speed #970628 11/04/09 03:05 AM
plh Offline OP
I am having a custom pan machined up from Aluminum 6061-T6 for my KM145 5 speed. If there is any interest please express it now and I'll have a few more made. These will come with 12 grade 5 - M8 studs, washers and nuts and can have a provision for an oil temperature sensor. Ballpark pricing is $100. Should know firm by the end of the week.
Plan is to have a few strain gages mounted on the current stamped steel stock set-up and compare once this is mounted to determine stiffness difference.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Strengthening KM145 5 speed [Re: plh] #970629 11/04/09 08:04 AM
This will help the KM145 guys a lot because it will help limit the flex of the housing under torque which is the main killer of the 145. I had made one of these about 4 years ago and nobody understood the point and only one guy bought one and i never heard back from him so i assume it worked wonderfully because i think he was destroying 145's on a regular basis.
Once you figure the difference in housing flex and post the gain you'll have my seal of approval. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Strengthening KM145 5 speed [Re: plh] #970630 11/04/09 08:48 AM
Kevin C Offline
A key factor to making the stiffer pan "close the box" and reduce case flex is to use an adhesive type sealer instead of a gasket.
Loctite makes a couple of good ones.
Kevin
Re: Strengthening KM145 5 speed [Re: plh] #970631 11/04/09 03:38 PM
shadowgear Offline
Put me down for 2. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking.
'03 Monty Sport - XLS, BFG A/T's - Dead
Re: Strengthening KM145 5 speed [Re: TOASTY] #970632 11/04/09 09:00 PM
0778drz110 Offline
Should I buy one if I plan to run 35s, 4.88s and a stock 2.6? I kinda wondering if it would break with the 35s even with a stock motor... <img src="/forums/images/graemlins/confused.gif" alt="" /> The 4.88s will help a bit, I kinda like to romp on the gas when I'm in the powerband though <img src="/forums/images/graemlins/scared.gif" alt="" />
I tell you what Phil, if you make one and install it with no problems I'm down for one <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Strengthening KM145 5 speed [Re: 0778drz110] #970633 11/04/09 09:09 PM
PA_JERO's diesel pickup would eat KM145's like crazy on road with 30" tires and that's going easy on the thing, they just couldn't take the torque of the 2.3L engine. I'm suprised you haven't already replaced your 5spd, usually just putting it in 4lo is too much for those things.
Re: Strengthening KM145 5 speed [Re: plh] #970634 11/04/09 11:31 PM
Interest expressed... <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Strengthening KM145 5 speed [Re: plh] #970635 11/04/09 11:43 PM
Mikewarme Offline
I'd be like at least 1 !
Re: Strengthening KM145 5 speed [Re: TOASTY] #970636 11/05/09 12:22 AM
Kevin C Offline
How much torque did the diesel put out? I have run 250 ft lbs through one with out a problem.
Was it the same unit thats behind the 2.6 in the Montero or was it the D50 2.6 tranny with the clutch cable?
Kevin
Re: Strengthening KM145 5 speed [Re: Kevin C] #970637 11/05/09 01:37 AM
powerRam50 Offline
i dont know,i put the km145 thru some nasty stuff and they have done ok.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-05-28 08:09:26 UTC
