Valid form? #970806 11/05/09 05:10 PM
BobRowe Offline OP
When I try to "Quick Reply
to a thread, I enter the text and then click on "Continue". It then tells me that the form I tried to use is no longer valid. I tried several times. What's p?
Re: Valid form? [Re: BobRowe] #970807 11/06/09 05:48 AM
4x4Wire Offline
The "Quick Reply" comment box should be present anytime you view a forum topic.
You should be able to enter a response in the comment box and hit "Continue" to submit it.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Valid form? [Re: 4x4Wire] #970808 11/06/09 05:59 AM
4x4Wire Offline
Okay, I have been able to duplicate your error.
No immediate resolution other than to encourage you to use the auto text entry box and not select through the "Quick Entry" mode.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5902 MB (Peak: 0.6433 MB) Data Comp: Off Server Time: 2026-07-16 10:14:34 UTC
