Clutch Fluid
#971273
11/09/09 06:43 AM
I was just wondering if there is any way to drain and refill the clutch fluid on a 96 toyota t100 4x4 without being a huge pain in the butt.
Re: Clutch Fluid
[Re: uareahosereh]
#971274
11/09/09 07:33 AM
Syringe... <img src="/forums/images/graemlins/wink.gif" alt="" /> Siphon... <img src="/forums/images/graemlins/smile.gif" alt="" /> Turkey baster works okay...but it can drip a lot unless you plug the end with yer finger. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Clutch Fluid
[Re: BamZipPow]
#971275
11/09/09 04:14 PM
Toyota Moderator
Remove as much fluid as you can from the reservoir (syringe, rags, etc) and then fill it with fresh fluid. Next, crack open the bleeder on the slave cylinder and let it gravity bleed while keeping an eye on the reservoir so that it doesn't run too low. Let it drain until clean fluid starts coming out the bleeder.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5916 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-06-03 17:44:33 UTCValid HTML 5 and Valid CSS
