Page 2 of 3 1 2 3
Re: Bent idler (pending solution) PIC [Re: LRJ4x4] #972111 11/16/09 05:08 AM
ryany Offline
It's the AZ rocks. smile
95 Montero SR
Re: Bent idler (pending solution) PIC [Re: PA_JERO] #972112 11/16/09 06:23 AM
GreatWhiteShark Offline
Not for sure on this, but didn't somebody use a pitman arm out of a non power steering 83 mighty max as there idler arm?
i remember reading a thread called " the strongest idler arm ever " or something like that. it was from a steering box i think also?
wasn't his nick Nittberg or similar ? <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Bent idler (pending solution) PIC [Re: GreatWhiteShark] #972113 11/16/09 06:34 AM
I found it
here it is
Strongest Idler Arm
too bad his pictures are no longer working
Re: Bent idler (pending solution) PIC [Re: GreatWhiteShark] #972114 11/16/09 07:24 AM
TOASTY Offline OP
It was Nitte and yes a steering gear will also do the trick.
Les, all those guys bend these things but yeah i bend everything (it's the Az rocks like Ryany said)
As for the welded tab i hadn't seen that before i'll have to ask him how well it worked. My plan is for a bolt on new mount like the ones the nissan guys use.
Our arms are beefier than theirs but same concept
Re: Bent idler (pending solution) PIC [Re: TOASTY] #972115 11/16/09 07:33 AM
Tag Offline
Wow! Their arms look like crap.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Bent idler (pending solution) PIC [Re: Tag] #972116 11/16/09 12:10 PM
Mad_Scientist Offline
Yeah, no kidding.
toasty, I don't think you will have enough threads at the end of the shaft to add all that. You'll need something like a couple of big washers between the arm and new bracket to stop it either binding or grinding away at each other because you'll have the arm rotating against a fixed bracket.
I have thought about this problem for a while and so I'm interested in what you come up with <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Bent idler (pending solution) PIC [Re: Mad_Scientist] #972117 11/16/09 05:03 PM
TOASTY Offline OP
I'm going to look for a bearing or machine up a bushing, and i should have room for a 1/4" plate and still have plenty of threads for the nut.
Re: Bent idler (pending solution) PIC [Re: Mad_Scientist] #972118 11/16/09 05:11 PM
TOASTY Offline OP
Oh forgot to post esrlier the arms i've been bending are the autozone ones but i bent the original just the same.
Re: Bent idler (pending solution) PIC [Re: TOASTY] #972119 11/16/09 09:33 PM
LRJ4x4 Offline
I like the bolt on mount idea. A few more items like that and you will need a web site for taking orders <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Bent idler (pending solution) PIC [Re: TOASTY] #972120 11/16/09 11:17 PM
I'm with Toasty on the "using Auto Zone parts that fail anyway" thing. At least you only have to pay for the part once. If they're dumb enough to lifetime warranty a part like that, I'm dumb enough to buy it.
I like the bracket idea, if you can make it work, Toast.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6435 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-06-22 11:17:56 UTC
