Page 3 of 3 1 2 3
Re: Bent idler (pending solution) PIC [Re: JohnnyBfromPeoria] #972121 11/17/09 04:36 AM
Mad_Scientist Offline
I'm with Toasty on the "using Auto Zone parts that fail anyway" thing. At least you only have to pay for the part once. If they're dumb enough to lifetime warranty a part like that, I'm dumb enough to buy it.
That's a good point, especially since they are the same price as OEM
Re: Bent idler (pending solution) PIC [Re: Mad_Scientist] #972122 11/17/09 04:41 AM
Tag Offline
I like the bracket idea, if you can make it work, Toast.
Oh by the way I work for Autozone now. Or I will be on 11-23. Not in retail.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Bent idler (pending solution) PIC [Re: Tag] #972123 11/17/09 07:54 AM
TOASTY Offline OP
I worked for them for 2 years and i suggested they make the idlers stronger for monteros or they're wasting their money. 100 Idlers later between all of us down here and they still suck.
Ok so I plan on picking up a spare Gen 2 idler to make a fixture out of it for making the support mounts, same goes for the gen 1 idlers. I'm hoping this will be as simple as i'm thinking it will be.
Re: Bent idler (pending solution) PIC [Re: TOASTY] #972124 11/17/09 12:37 PM
I would consider removing the nut and replacing it with a machined extension that threads on so the bearing you add is further down giving it more leverage to keep thing straight.
Re: Bent idler (pending solution) PIC [Re: OldColt] #972125 11/17/09 01:22 PM
That's a good idea <img src="/forums/images/graemlins/kewl.gif" alt="" />
It's also worth mentioning again that the zombiezone idler arm as a longer shaft compared to the OEM. On the OEM unit there are not enough threads for this brace idea to work, making Charlie's suggestion all the more important <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6176 MB (Peak: 0.6829 MB) Data Comp: Off Server Time: 2026-06-20 19:09:35 UTC
